Where to put help?
20 of 20 messages available
Where to put help? John Culleton 10 Dec 13:45
  Where to put help? Sven Neumann 11 Dec 12:11
   Where to put help? John Culleton 11 Dec 20:54
    Where to put help? Jozsef Mak 11 Dec 22:29
     Where to put help? Michael Schumacher 11 Dec 22:50
      Where to put help? Jozsef Mak 12 Dec 01:24
     Where to put help? Carol Spears 12 Dec 00:54
     Where to put help? Sven Neumann 12 Dec 01:32
      Where to put help? John Culleton 15 Dec 22:13
       Where to put help? Sven Neumann 16 Dec 02:17
        Where to put help? Jozsef Mak 16 Dec 06:05
    Where to put help? Owen Cook 11 Dec 23:09
    Where to put help? Carol Spears 12 Dec 03:11
    Where to put help? Sven Neumann 16 Dec 02:40
     Where to put help? Jogchum Reitsma 19 Dec 14:48
      Where to put help? Michael Schumacher 19 Dec 15:20
       Where to put help? Jogchum Reitsma 19 Dec 17:02
      Where to put help? Sven Neumann 19 Dec 16:14
Where to put help? Michael Schumacher 16 Dec 10:06
Where to put help? Bob Long 17 Dec 10:39
John Culleton
2004-12-10 13:45:34 UTC (almost 21 years ago)
Where to put help?
I have downloaded the latest help file. Befor I untar it, where is it supposed to go? Or more particularly, where is it supposed to be when I untar it?
It would be very nice if the help files were integrated with the Gimp distribution, and matched that distro feature for feature.
While searching my disk I find that I have several Gimp versions, one of which is in /usr/local/usr/share. Obviously I untarred that puppy in the wrong location. Hence my question above.
2004-12-11 12:11:15 UTC (almost 21 years ago)
Where to put help?
John Culleton writes:
Just untar them and read the installation instructions in the file INSTALL.
John Culleton
2004-12-11 20:54:07 UTC (almost 21 years ago)
Where to put help?
OK the instructions say run ./configure and ./configure fails because it can't find a file called gimp-2.0 pc. I searched my disks (several versions of Gimp laying around) and no such file exists. The ./configure run also says: "couldn't find a Gimp-2.0 installation". There are about three laying around.
So, back to my original question. Where should I try to untar the Gimp help tarball? I don't want to muck up a functioning Gimp installation by untarring them in the wrong location.
Perhaps I am using the wrong tarball. When you go to the site and look for help files all you can find is a directory called "test" or "testing" which holds about 5 different versions of help files. I picked out the most recent one, 2.05
The best solution of course would be to have the help files integrated with the Gimp package itself. That is the way most packages work. Failing that, a help tarball in parallel to the current stable version and with explicit instructions on installation (i.e. where) would be most helpful. I suppose I will have to go to a Knoppix disk and figure out where the help files go from its internal structure. Oh well.
Jozsef Mak
2004-12-11 22:29:59 UTC (almost 21 years ago)
Where to put help?
I also cannot understand the reason behind not integrating the help files with Gimp.
jozsefmak
John Culleton
Short list of publishing/marketing books: http://wexfordpress.com/tex/shortlist.pdf
2004-12-11 22:50:25 UTC (almost 21 years ago)
Where to put help?
> I also cannot understand the reason behind not integrating the help > files with Gimp.
At which level would you like to integrate it - source tree, release tarball or binary distribution?
Owen Cook
2004-12-11 23:09:24 UTC (almost 21 years ago)
Where to put help?
You should have several gimp-2.0.pc files if you have several installations. You will need to find them. Standard locations would be for example;
/usr/lib/pkgconfig/gimp-2.0.pc /usr/local/lib/pkgconfig/gimp-2.0.pc /opt/lib/pkgconfig/gimp-2.0.pc
Determine which gimp you want the help files to be associated with, eg the one in say /usr/local
Then export your PKG_CONFIG_PATH
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig/
Now check it
pkg-config --modversion gimp-2.0
Then try installing your help
Owen
Carol Spears
2004-12-12 00:54:03 UTC (almost 21 years ago)
Where to put help?
oh, i can answer this. have you ever tried to build these things?
maybe they build easier right now, but i have had my workflow interrupted because i could not build the help documentation for gimp. i needed gimp, not help documents.
i have not tried to build them recently. i am waiting for something other than docbook format. i would rather tinker with gap than learn more of the evil of docbook; it really does some things that i would never ever do to people in documentation. so, since i do not really know what it is like to build the documents lately, can someone provide a dependency list of the things needed to build the help docs?
also, my bad feelings of the method have nothing to do with the text the format contains, nor the people who endure what i consider rude and inefficient means of writing documentation. even the people who designed it, this has nothing to do with any personal feelings there.
long ago, gimp depended on emacs to build its help documentation. this made and still makes me laugh some. consider having jade suggested to help you install gimp? i would rather gimp depend on emacs, in fact, maybe this is the solution ....
Jozsef Mak
2004-12-12 01:24:37 UTC (almost 21 years ago)
Where to put help?
This I cannot tell, but when I compiled Inkscape from source all the tutorials were in the help file ready to use. They could solve the problem somehow.
jozsefmak
The GIMP > http://www.gimp.org | IRC: irc://irc.gimp.org/gimp Wiki > http://wiki.gimp.org | .de: http://gimpforum.de Plug-ins > http://registry.gimp.org |
2004-12-12 01:32:59 UTC (almost 21 years ago)
Where to put help?
"Jozsef Mak" writes:
We did so in the past and it was a nightmare to maintain. Development on gimp-help works a lot better since it is decoupled from GIMP releases. For the end user who's using some sort of package management system or an installer, there's no difference anyway. The help files get installed with the GIMP packages.
Carol Spears
2004-12-12 03:11:51 UTC (almost 21 years ago)
Where to put help?
the solution to this is to show ./configure where the file (gimp-2.0.pc) is. running the "gimpenv" script from wgo should fix that: http://www.gimp.org/source/howtos/gimpenv
it tells your shell what it needs to know by setting the proper environment variables.
you are imagining opening up a tarball of html, i think. what you have downloaded is the means to make html, pdf, sgtml, xml and whoknowwhatelseml. your question is not being asked correctly.
a tarball of html because that is all anyone will ever use? you jest!
John Culleton
2004-12-15 22:13:49 UTC (almost 21 years ago)
Where to put help?
As it happens, Slackware and Knoppix (some versions) have Gimp but the help files are not included. Either the maintainers of these distros don't know about the separate help files or they can't figure out how to install them. (Neither can I.)
I will inquire in the appropriate lists.
Is there a Linux distro anywhere that preinstalls the help files with Gimp?
2004-12-16 02:17:44 UTC (almost 21 years ago)
Where to put help?
The user manual isn't considered ready for general consumption yet so it isn't surprising that the help isn't shipped with GIMP by default yet. I hope that the GIMP help team will release a first stable version of the manual soon.
(Neither can I.)
Oh come on. It's as simple as unpacking the tarball and typing 'configure; make; make install'. If you can't figure that out yourself, perhaps you should ask someone who isn't completely clueless.
2004-12-16 02:40:02 UTC (almost 21 years ago)
Where to put help?
gimp-2.0.pc is installed into $prefix/lib/pkgconfig. It's a standard thing that a lot of software packages use these days. Please consider to read the pkg-config man-page to learn more about it. The man-page will also explain you how to use the PKG_CONFIG_PATH environment variable to point pkg-config to .pc files that are not in the default search path.
Yes, there's no final gimp-help-2 tarball yet. The help authors don't think their work is ready for general consumption yet.
Sure. As soon as the manual is released by the people writing it, we will include instructions as how to install it. If you want to make this happen earlier, consider to join the gimp-help-2 team.
Jozsef Mak
2004-12-16 06:05:56 UTC (almost 21 years ago)
Where to put help?
How do you install it on the windows version?
To: John Culleton
CC: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Where to put help? Date: Thu, 16 Dec 2004 02:17:44 +0100
help
know
them.
(Neither can I.)
2004-12-16 10:06:02 UTC (almost 21 years ago)
Where to put help?
You use the help installer package.
HTH, Michael
Bob Long
2004-12-17 10:39:09 UTC (almost 21 years ago)
Where to put help?
Help, which will work with GIMP 2.0.5, is here: http://gimp-win.sourceforge.net/stable.html
Unzip and put into: C:\Program Files\GIMP-2.0\, or wherever your GIMP is installed. Preserve the directory structure that is in the ZIP file.
Bob Long
Jogchum Reitsma
2004-12-19 14:48:11 UTC (almost 21 years ago)
Where to put help?
I'm afraid I have to confirm John's problem: there simply is no file called gimp-2.0.pc on my system.
So the question is IMHO not how to direct configure to the place the file is on disk (there is no such place) but where that file can be found on the internet. It's obviously not in our gimp-2.0 distribution (in my case, the Gimp-version comes with my Suse 9.2 distro. Could it be that the problem lies in the fact that Suse uses the RPM package manager?
search path.
2004-12-19 15:20:42 UTC (almost 21 years ago)
Where to put help?
Maybe there is a seperate gimp-dev (or libgimp-dev) package?
BTW, could you please fix your quoting? Thank you.
HTH, Michael
2004-12-19 16:14:01 UTC (almost 21 years ago)
Where to put help?
Jogchum Reitsma writes:
You are missing the gimp-devel package then. If you want to install the user manual from source, you need to have the GIMP development package installed. Otherwise you should be using the gimp-help package that your distribution provides. If it doesn't provide one, you should ask them to do add one.
There's a workaround that allows you to install gimp-help-2 w/o having GIMP installed or w/o having the GIMP development package installed. It's mentioned in the installation instructions that come with gimp-help-2 (look at the file INSTALL).
Jogchum Reitsma
2004-12-19 17:02:12 UTC (almost 21 years ago)
Where to put help?
HTH, Michael
That's it! Thanks!
Btw: this quoting better?
kind greetings, Jogchum
