difference between merge and flatten layers
5 of 6 messages available
difference between merge and flatten layers Gert Cuykens 09 Dec 21:45
  difference between merge and flatten layers Matthew H. Plough 10 Dec 02:23
41B8FA5C.7080006@princeton.edu 07 Oct 20:16
  difference between merge and flatten layers Gert Cuykens 10 Dec 02:31
   difference between merge and flatten layers David Neary 10 Dec 09:57
   difference between merge and flatten layers Sven Neumann 10 Dec 12:50
Gert Cuykens
2004-12-09 21:45:10 UTC (almost 21 years ago)
what is the difference between merge and flatten layers ?
Matthew H. Plough
2004-12-10 02:23:19 UTC (almost 21 years ago)
You're talking about merge down, right? Merge down combines the selected layer and the first visible layer below it into one layer. Flatten merges all layers into one. Of course, both take your blend mode, alpha, etc. into account. Does that answer your question?
Matt
Gert Cuykens
2004-12-10 02:31:32 UTC (almost 21 years ago)
Matt
yes, except why does flatten image don't show the same prompt menu as merge visible layers ?
expanded as necessary clipped to image
clipped to bottom layer
what do does options mean ?
David Neary
2004-12-10 09:57:52 UTC (almost 21 years ago)
Merge down and Merge visible layers merge several layers, but can leave other layers untouched. Thus, when you are merging more than one layer, you have a number of ways to do it - the new layer can be limited by the size of the image, by the size of the bottom layer, or by the union of all of the layers being merged (expand as necessary).
Flatten image performs another operation - it removes all of the layers (visible or not) and replaces them with one layer, which does not have any transparency. Any transparency in the projection is combined with the background color.
Cheers, Dave.
2004-12-10 12:50:26 UTC (almost 21 years ago)
Gert Cuykens writes:
What about pressing F1 in the Merge Dialog and reading about it in the user manual?
