difference between modules and plugins
7 of 7 messages available
difference between modules and plugins Gert Cuykens 08 Dec 20:49
  difference between modules and plugins Sven Neumann 08 Dec 23:44
   difference between modules and plugins Gert Cuykens 08 Dec 23:50
    difference between modules and plugins Simon Budig 09 Dec 00:20
    difference between modules and plugins Sven Neumann 09 Dec 00:47
     difference between modules and plugins Gert Cuykens 09 Dec 03:46
      difference between modules and plugins Sven Neumann 09 Dec 09:52
Gert Cuykens
2004-12-08 20:49:06 UTC (over 20 years ago)
what is the difference between a module and a plugin ?
2004-12-08 23:44:35 UTC (over 20 years ago)
Gert Cuykens writes:
A plug-in runs as it's own process and can use the full libgimp API. A module is some piece of code loaded at run-rime by the gimp process. It has to implement a certain set of methods and can only use a limited API.
Gert Cuykens
2004-12-08 23:50:38 UTC (over 20 years ago)
why does gimp have modules ? why not make only plugins ?
Simon Budig
2004-12-09 00:20:39 UTC (over 20 years ago)
Because modules have a tighter integration with the GIMP and can e.g. provide additional color selectors embedded in the Gimp-GUI or invoke actions.
Their API is more limited but plugins *have* to be more separated from the core.
Bye,
Simon
2004-12-09 00:47:58 UTC (over 20 years ago)
They serve completely different purposes. Modules are ways to add alternative implementations of core functionality. At the moment there are three kind of module interfaces that can be implemented:
http://developer.gimp.org/api/2.0/libgimpwidgets/GimpColorSelector.html http://developer.gimp.org/api/2.0/libgimpwidgets/GimpColorDisplay.html
and GimpController, a modular interface to input events. The API docs for this new type of modules is not yet online.
Gert Cuykens
2004-12-09 03:46:02 UTC (over 20 years ago)
ok i think i understand
modules enhance the gimp gui plugins enhance the image you are working on
can you explain why modules API is more limited please ?
2004-12-09 09:52:46 UTC (over 20 years ago)
You didn't really understand the purpose of modules if you are still asking this. Well, I don't know how to explain it any better. Perhaps you should have a look at the code.
