layer dialog
2 of 3 messages available
layer dialog Gert Cuykens 06 Dec 20:47
41B4DC1B.5060002@zimny.webd.pl 07 Oct 20:16
  layer dialog Gert Cuykens 07 Dec 02:58
Gert Cuykens
2004-12-06 20:47:47 UTC (over 20 years ago)
layer dialog
what does Anchor Layer do?
what does the chain symbol next to the eye mean ?
Gert Cuykens
2004-12-07 02:58:34 UTC (over 20 years ago)
layer dialog
thx
if you select the anchor next to several layers, and you select one of them as active,
you can make changes (try move tool for example) to all of them at once.
mean the chain symbol not the anchor button. u use anchor when - for exmple - you pasted selection (if floats) and you need to anchor it - it will be pasted on last active layer.
cheers
