Photoshop's "accented edge" effect?
Photoshop's "accented edge" effect? " 05 Dec 08:59
Photoshop's "accented edge" effect? bear 06 Dec 03:17
  Photoshop's "accented edge" effect? Alan Horkan 06 Dec 21:53
  Photoshop's "accented edge" effect? Øyvind Kolås 09 Dec 01:29
Photoshop's "accented edge" effect? bear 09 Dec 03:21
2004-12-05 08:59:33 UTC (over 20 years ago)
hi gimp users,
Is there any similar effect filter or script-fu like Photoshop's "accented edge" filter? PS's effects are attached(edge.jpg is original, edge.jpg is the certain effect). Thanks!
bear
bear
2004-12-06 03:17:14 UTC (over 20 years ago)
The "accent edge" effect is at
http://learn.tsinghua.edu.cn/homepage/2003216147/edge.jpg The original image is at
http://learn.tsinghua.edu.cn/homepage/2003216147/orig.jpg
Thanks!
Reply-To:
To: xgl99@mails.tsinghua.edu.cn
Subject: Re: [Gimp-user] Photoshop's "accented edge" effect?
Looks like the list rejectd your attachments
Can you put them on a webpage and send a link to the page instead?
Sincerely
Alan Horkan
Free SVG Clip Art http://OpenClipArt.org Dia is for Diagrams http://gnome.org/projects/dia/ Alan's Journal http://advogato.org/person/AlanHorkan/
Inkscape, Draw Freely http://inkscape.org Abiword is Awesome http://abisource.com
On Sun, 5 Dec 2004, wrote:
Date: Sun, 05 Dec 2004 15:59:33 +0800 From:
To: gimp-user@lists.xcf.berkeley.edu Subject: [Gimp-user] Photoshop's "accented edge" effect?
hi gimp users, Is there any similar effect filter or script-fu like Photoshop's
"accented
the
bear
Alan Horkan
2004-12-06 21:53:57 UTC (over 20 years ago)
On Mon, 6 Dec 2004, bear wrote:
Date: Mon, 06 Dec 2004 10:17:14 +0800 From: bear
To: horkana@maths.tcd.ie
Cc: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Photoshop's "accented edge" effect?
The "accent edge" effect is at http://learn.tsinghua.edu.cn/homepage/2003216147/edge.jpg The original image is at
I'm not sure how to recreate exactly that effect you describe but there are similar ones available under
Filters, Edge-Detect,
Edge
Laplace
Sobel
Hope that helps
Sincerely
Alan Horkan
Øyvind Kolås
2004-12-09 01:29:22 UTC (over 20 years ago)
Would it be possible to get access to a PNG version of the original image, due to the noise introduced in the jpeg compression it is very hard to evaluate what effect is intended.
/pippin
bear
2004-12-09 03:21:40 UTC (over 20 years ago)
