Erase Text Keep Paper
Erase Text Keep Paper lanierprintables 21 Nov 16:23
  Erase Text Keep Paper rich2005 21 Nov 18:06
  Erase Text Keep Paper Rick Strong 21 Nov 20:55
2016-11-21 16:23:36 UTC (over 8 years ago)
Can anyone help me figure out how to erase the text but keep the paper look behind it? I use Gimp but I'm very beginner. Any input would be so helpful! Thanks so much!
2016-11-21 18:06:25 UTC (over 8 years ago)
How much text do you want to remove?
That image is fairly low quality, lots of jpeg artifacts.
Unlikely that any single operation is best.
Resynthesizer + heal selection for some parts. See the earlier post on installing resynthesizer.
G'mic plugin www.gmic.eu In the repair section, the inpaint-metamorphical filter works for the larger text.
Going to be some cleaning up with the regular gimp clone tool.
Rick Strong
2016-11-21 20:55:00 UTC (over 8 years ago)
Why don't you take a piece of paper, fold it, scrunch it up a bit then scan it in greyscale (or rgb)?
Or just take a photo of it.
Rick S.
-----Original Message----- From: lanierprintables
Sent: Monday, November 21, 2016 11:23 AM To: gimp-user-list@gnome.org
Subject: [Gimp-user] Erase Text Keep Paper
http://www.gimpusers.com/system/attachments/334/original/icm_fullxfull.107697011_qfoqwv3iz9c0kk4wwwkg.jpg
lanierprintables (via www.gimpusers.com/forums)
