Can I open and edit the Gimp in netbeans using C++?
Can I open and edit the Gimp in netbeans using C++? John Smith 26 Oct 14:39
  Can I open and edit the Gimp in netbeans using C++? Alexandre Prokoudine 26 Oct 14:43
John Smith
2016-10-26 14:39:30 UTC (over 8 years ago)
The title says it all. If I go for the Gimp, will I be able to open the source file in Netbeans and tweak it to my needs using C++?
I'll stick with the tarballs at the beginning.
Cordialement,
John
http://johnsmithimages.net
2016-10-26 14:00 GMT+02:00 :
Send gimp-user-list mailing list submissions to gimp-user-list@gnome.org
To subscribe or unsubscribe via the World Wide Web, visit https://mail.gnome.org/mailman/listinfo/gimp-user-list or, via email, send a message with subject or body 'help' to gimp-user-list-request@gnome.org
You can reach the person managing the list at gimp-user-list-owner@gnome.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of gimp-user-list digest..."
Today's Topics:
1. Luminosity Masks (Andrew Clarke)
Message: 1 Date: Wed, 26 Oct 2016 09:17:12 +0100 From: Andrew Clarke
To: "gimp-user-list@gnome.org"
Subject: [Gimp-user] Luminosity Masks Message-ID:
Content-Type: text/plain; charset=utf-8
OSX GIMP 2.8.14 - http://gimp.lisanet.de
If I apply a luminosity mask to an image by selecting a RGB channel(from a layer that has been desatuarated via luminosity) with any of red, green or blue channels as the mask, if I then go on to adjust by curves (*value*) I get a shift in colour, as you would expect if you where using red,green or blue separately in curves not by value.
Alternatively if I create a new layer desaturated to luminosity as you would before, but then drag that *layer* to the channel dialog box,then apply that new channel as a layer mask, I get the expected adjustment using curves(value) that it does not shift the colour.
Also if I apply a mask from a RGB channel, then remove that mask and layer, also delete the dragged channel, add a new layer I cannot desaturate that new layer as it maintains colour. If I do the same with the original layer (opened image) you can desaturate that original layer.
Thanks Andrew
Subject: Digest Footer
End of gimp-user-list Digest, Vol 61, Issue 39 **********************************************
2016-10-26 14:43:32 UTC (over 8 years ago)
26 окт. 2016 г. 5:39 PM пользователь "John Smith" написал:
GIMP is written in C, some plugins are in Scheme and Python.
Alex
