Is it possible to save layer effects
Is it possible to save layer effects calcat 20 Oct 19:19
  Is it possible to save layer effects Ofnuts 20 Oct 23:08
2016-10-20 19:19:49 UTC (over 8 years ago)
I'm using Linux exclusively. I'm learning GIMP again and am really happy with the layer FX and other filters, especially. GIMP is great depth.
I have Photoshop Elements 10, can't get it to work properly in Wine or Crossover (type tool issues, porting over other .asl files, opening some .psd files but not others). I prefer not to use it in Windows, which I could boot into, because it's... Windows HA!
In GIMP, is there any way at all to save layer effects that I've used, so that I can use them again? It's something that I often have need of. Currently, I'm creating a text file, for each instance, that lists settings for bevel, drop shadow, colour, etc. It would be great if there were a work-around for this.
From my reading I've learned that there isn't a macro-recorder sort of thing, and I'm not sure if a script would work, even if I were able to create something like that at this point.
I've done a lot of searching, and finally decided to go to the source :)
TIA,
2016-10-20 23:08:27 UTC (over 8 years ago)
A script would very likely work.
