Eraser not working
Eraser not working kickoff3pm 16 Oct 20:54
  Eraser not working Jehan Pagès 18 Oct 00:13
   Eraser not working kickoff3pm 18 Oct 08:48
2016-10-16 20:54:53 UTC (over 8 years ago)
Eraser not working
Hello everyone, I've not been using Gimp for long and I only really use it for creating Facebook headers. I often copy in other images as a layer and then erase part of the copied image. My problem is after a few times doing this the eraser stops working and I can't see a way around it. I've deleted and started again with the layer and close and reopened the file. But once I get to this point I can't erase anything.
Is this a bug or have I done something wrong?
Jehan Pagès
2016-10-18 00:13:03 UTC (over 8 years ago)
Eraser not working
If the layer you are trying to erase on has no alpha channel, then the eraser will paint in the background color instead of making the pixels transparent. Could it be your problem, by any chance? Another thing I can think of: do you have several layer and are you erasing the right one?
Again: would you have an active selection and you try to erase outside of the selection? Go in menu: "Select" > "None".
If not one of these, please could you explain what you mean by "the eraser stops working". What is happening when you try to erase? We need more details to not have to guess what you are experiencing. Regards,
Jehan
kickoff3pm (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
ZeMarmot open animation film
http://film.zemarmot.net
2016-10-18 08:48:57 UTC (over 8 years ago)
Eraser not working
Jehan
Well I will try to remember that for the future, in this case when I opened the file again the next day it worked fine.
More explanation: I am creating a new image from pasting images as layers and editing them. I paste then erase parts. I can do this 10 or 20 time when for some reason the eraser does nothing. In doesn't erase the pasted layer or the background it has no effect at all. I'm wondering if it's a memory problem?
