Alpha mode
Alpha mode Pippi 15 Oct 19:25
  Alpha mode Steve Kinney 17 Oct 18:57
  Alpha mode Ofnuts 18 Oct 12:24
2016-10-15 19:25:57 UTC (over 8 years ago)
Alpha mode
I'm a beginner and usually use Gimp to change jpg's to png's. When I tried to change the attached image, I had some leftover white. I inverted image> changed to alpha channel>fuzzy select> cut. I cannot fuzzy select all the little detailed white sections, that were leftover. Is there something different I can do, to get the entire image transparent?
2016-10-17 18:57:45 UTC (over 8 years ago)
Alpha mode
That sounds like a simple problem, but the intended attachment did not make it through and that makes it hard to tell exactly what the problem is. Try again?
:o)
2016-10-18 12:24:11 UTC (over 8 years ago)
Alpha mode
Use Color->Color to alpha and remove the white. if parts of the subject become partially transparent, use a selection to exclude them.
