reloading of python-fu scripts
reloading of python-fu scripts Stefaan Lippens 23 Nov 20:48
  reloading of python-fu scripts Carol Spears 23 Nov 21:37
  reloading of python-fu scripts Alan Horkan 24 Nov 00:49
Stefaan Lippens
2004-11-23 20:48:15 UTC (over 20 years ago)
Is it possible to reload python-fu scripts without restarting the Gimp, like "Xtns"/"Script-fu"/"Refresh Scripts" for script-fu?
Carol Spears
2004-11-23 21:37:51 UTC (over 20 years ago)
once it loads, you can change the script and the changes appear without restarting gimp; that is if your edits did not break the script.
you cannot add new scripts without restarting gimp.
Alan Horkan
2004-11-24 00:49:19 UTC (over 20 years ago)
On Tue, 23 Nov 2004, Stefaan Lippens wrote:
Date: Tue, 23 Nov 2004 19:48:15 +0000 From: Stefaan Lippens
To: gimp-user@lists.xcf.berkeley.edu Subject: [Gimp-user] reloading of python-fu scripts
They should reload automatically.
I had problems with temp-files.py~ being picked up instead of the real file so you should set your editor to store temp files elsewhere if you are editing them directly.
- Alan
