Print command
10 of 10 messages available
Print command Matthias Julius 22 Nov 19:34
  Print command Patrick Shanahan 22 Nov 21:18
Print command Matthias Julius 23 Nov 00:48
  Print command Patrick Shanahan 23 Nov 01:27
   Print command Geoffrey 23 Nov 02:15
Print command Matthias Julius 23 Nov 03:23
  Print command Sven Neumann 23 Nov 10:49
  Print command Geoffrey 23 Nov 12:47
  Print command Joao S. O. Bueno Calligaris 23 Nov 13:19
Print command Matthias Julius 23 Nov 17:36
Matthias Julius
2004-11-22 19:34:58 UTC (over 20 years ago)
Print command
I am printing over CUPS using 'lpr' as print command. That works fine. Now I would like to pass the file name of the file being printed to lpr (via 'lpr -C'). Is that possible?
Matthias
Patrick Shanahan
2004-11-22 21:18:40 UTC (over 20 years ago)
Print command
* Matthias Julius [11-22-04 14:55]:
issue from a command-line 'man lpr'. Then, if you do not understand, ask again.
Matthias Julius
2004-11-23 00:48:17 UTC (over 20 years ago)
Print command
Patrick Shanahan writes:
I know 'man lpr'. It says:
-C name Sets the job name.
But how can I get gimp to include the file name in the print command after the -C?
Matthias
Patrick Shanahan
2004-11-23 01:27:58 UTC (over 20 years ago)
Print command
* Matthias Julius [11-22-04 19:18]:
Are you trying to print from a gimp image -> File -> Print ? If so, set the print dialogue screen to your printer via the drop down box and print direct from gimp. You do not need to worry about -C name. I have an Epson sp925photo and the print-command which gimp selects for my printer is: lp -s -desp925gp -oraw
If this is *not* what you are trying to do, please explain further.
Geoffrey
2004-11-23 02:15:47 UTC (over 20 years ago)
Print command
He wants to set the job name via -C:
From man lpr:
Matthias Julius
2004-11-23 03:23:37 UTC (over 20 years ago)
Print command
Yes I am printing from the Gimp print dialog. And changing the printer in the printer setup does not affect the print command Gimp is choosing.
And it is printing fine as I wrote in my original post.
The only problem I have is that in the print job list every print job from Gimp has the name '(stdin)'. I would like the name of the printed file to appear there and from the lpr side this is done via the '-C' option. Now I need Gimp to insert the file name into the print command. So the print command specification in the printer setup should be something like 'lpr -C $filename' where Gimp is replacing $filename with the actual file name.
BTW, I am printing through CUPS. I don't know whether CUPS' lpr differs from standard lpr.
Matthias
2004-11-23 10:49:35 UTC (over 20 years ago)
Print command
Matthias Julius writes:
Completely understodd. But that would need changes to the print plug-in. It is however scheduled to be replaced by a new plug-in for the next generation gimp-print library (or gutenprint which is its new name). If you want to see such a feature being added, please get in contact with the gimp-print/gutenprint developers. Their project is hosted on sourceforge.
Geoffrey
2004-11-23 12:47:34 UTC (over 20 years ago)
Print command
If in fact GIMP is printing via stdin, there will not be a file name associated. I suspect that you'll be out of luck as GIMP is probably not 'aware' of the file name at this point. After all, it may not even have a file name if you've just created the image. This is all speculation, thus you should likely wait to hear from someone who really knows. :)
Matthias
2004-11-23 13:19:01 UTC (over 20 years ago)
Print command
Ok,
so -- there is no way to do what you want. The only way would be to implement it into the print plugin, possibly making it exapand "%f" on this field to the filename.
On Tuesday 23 November 2004 00:23, Matthias Julius wrote: (...)
Matthias
Matthias Julius
2004-11-23 17:36:03 UTC (over 20 years ago)
Print command
Geoffrey writes:
I got a message from Sven per mail explaining that this is not available yet and I should talk to the developers of the print plugin. Although this mail was CC'd to the list it did not come through gmane yet.
However, if it is not the filename it could be the window name of the image window that is being printed. That usually includes the filename.
Matthias
