Help with jagged edges
Help with jagged edges chrisj 12 Sep 19:39
  Help with jagged edges ugajin@talktalk.net 15 Sep 12:08
  Help with jagged edges Kasim Ahmic 15 Sep 14:53
2016-09-12 19:39:14 UTC (over 8 years ago)
I have tried to add this simple 'play button" to a simple rectangle, but the ply button circle is not smooth-edged, can you help me smooth it, or suggest a solution, or provide me with another image, that I can use? See attached...
ugajin@talktalk.net
2016-09-15 12:08:06 UTC (over 8 years ago)
There are many free tutorials that will show you how to use GIMP to make graphic buttons. Try searching 'gimp buttons' or something.
----Original Message-->From: forums@gimpusers.com Date: 12/09/2016 20:39
To:
Cc:
Subj: [Gimp-user] Help with jagged edges
Attachments: * http://www.gimpusers.com/system/attachments/274/original/PlayButton3-1.png
-- chrisj (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
Kasim Ahmic
2016-09-15 14:53:41 UTC (over 8 years ago)
What I typically do is, using the Ellipse Selection Tool, I make a selection of whatever size I need the circle to be and fill it with a color. From there, I make a smaller selection within the first circle and clear it (Delete key or Edit > Clear). Also, make sure that anti aliasing is checked while doing this.
Btw, what method are you using to make the circle? Are you making a path and then stroking? If so, make sure you're using the paint brush tool and not the pencil. That may help as well.
Sent from my iPhone
