Problem with exporting as .bmp for MS Windows BITMAP resource
Problem with exporting as .bmp for MS Windows BITMAP resource BengtV 31 Aug 22:43
  Problem with exporting as .bmp for MS Windows BITMAP resource Richard 04 Sep 18:56
2016-08-31 22:43:14 UTC (almost 9 years ago)
I wanted to export an image as a .bmp file for use as a BITMAP resource in an MS Windows .rc file. The CBitmap method for loading the resource failed. The road to making the file usable turned out *not* to be as straight as I had hoped.
Looking at the header showed that the saved .bmp was compressed (type=3). I converted the file using ImageMagick to the older "bmp3" format. Now the file contained uncompressed (type=0) RGB data and loaded nicely into the application.
Now the problem was the alpha channel. Apparently, the ImageMagick team last year (on a request) added the possibility to force bmp3 to include the alpha channel with the --alpha flag. Now the image looked strange in areas where there was a gradient in the alpha. It seems like Windows wants the RGB data to be premultiplied with the alpha channel.
So, after a long time searching through forums, I finally came up with an ImageMagick command line which converted a .png to a .bmp (bmp3) with premultiplied alpha. Using this, my toolbar icons looked great, without any alpha-related border artifacts.
My questions are: 1. Has anyone experienced the same problem? (Besides the guy requesting the --alpha flag from the ImageMagick team) ;)
2. Why doesn't .bmp-export in GIMP have options to handle this? Is the image format used in any real extent on any other platform??? (Like "export for Windows resource compatibility")
Richard
2016-09-04 18:56:44 UTC (almost 9 years ago)
This is a known issue when exporting BMP files from within GIMP -- using RLE compression, colorspace or alpha channel in the target file is not supported by all BMP loaders, so check your Export options to be sure.
(This being said, I was unable to reproduce this scenario on my Win 10 system regardless of my export settings -- I have however encountered it in Windows XP.)
Sent: Wednesday, August 31, 2016 3:43 PM
To: gimp-user-list@gnome.org
Subject: [Gimp-user] Problem with exporting as .bmp for MS Windows BITMAP resource
Windows .rc file.
hoped.
application.
to force
channel.
ImageMagick
artifacts.
My questions are:
BengtV (via www.gimpusers.com/forums)
Forums - gimpusers.com
www.gimpusers.com
Forums. While there are many different GIMP forums of there, our own forums provide an extended way to communicate because they are connected to the official GIMP ...
