ATK needs Glib 2.2
ATK needs Glib 2.2 JBuck814366460@aol.com 17 Nov 20:13
  ATK needs Glib 2.2 Carol Spears 17 Nov 20:45
2004-11-17 20:13:24 UTC (over 20 years ago)
ATK needs Glib 2.2
Hi all, i have a minor problem with compiling the atk thing needed to make the GIMP work. It configures properly, but then i get an error message stating that while it found the latest version of Glib on my Linux machine (2.5 something?) it recommends then that i remove the old 2.2 version on the machine for the compile to proceed. Problem is, i don't know where or how to remove the old version.
Can anyone help me here? I'm new to compiling programs for use on Linux, so a little step-by-step walkthrough would be beneficial for me.
Cheers,
Jared
Carol Spears
2004-11-17 20:45:46 UTC (over 20 years ago)
ATK needs Glib 2.2
just a quick guess here, i think that you have an old development package from a distribution somewhere.
first thing to do is to determine how to remove software via your distributions package manager. debian uses "apt-get remove package-name", redhat and kin use "rpm -r package-name". packages with "-dev" in the name can cause two problems. they cause "make" to find header files in the wrong place or a wrong package-name.pc file in the package-config stuff.
i am going to warn you, i havent had trouble building gimp in a while, so there might be several details here that are not exactly correct or expressed very well.
a place i might start if i had this problem is "man pkg-config" and see what sort of information you can get from that.
