problem to compile gimp 2.0.5 on Solaris 9
problem to compile gimp 2.0.5 on Solaris 9 Luc Novalès 16 Nov 11:28
  problem to compile gimp 2.0.5 on Solaris 9 Sven Neumann 16 Nov 12:39
   problem to compile gimp 2.0.5 on Solaris 9 Luc Novalès 16 Nov 16:58
Luc Novalès
2004-11-16 11:28:35 UTC (over 20 years ago)
I can't acceed to recent archives on : https://lists.xcf.berkeley.edu/lists/gimp-user/ and I don't know if there was a similar thread.
I verified gimp requirement, and install libraries packages from : http://www.sunfreeware.com/
except for lib gtk2.2.4 (compiled on target host).
GIMP compile error is about undeclared param logo_data in ./plug-ins/gimpressionist/gimpressionist.c at line :
pixbuf = gdk_pixbuf_new_from_inline (-1, logo_data, FALSE, NULL);
It seems that it wait for an header in gdk, but where ? (This declaration is also required to compile on others platforms)
It compile if I declare logo_data explicitly as : guint8* logo_data;
but execution produces a segmentation fault as :
7:02 30 -> gimp --verbose --console-messages --stack-trace-mode always 0 INIT: gimp_load_config
Lecture de « /usr/local/etc/gimp/2.0/gimprc » Lecture de « /home/my-home/.gimp-2.0/gimprc » gimp_composite: use=yes, verbose=no
Processor instruction sets: -mmx -sse -sse2 -3dnow -altivec -vis Ajout du thème « Default » (/usr/local/share/gimp/2.0/themes/Default) Ajout du thème « Small » (/usr/local/share/gimp/2.0/themes/Small) Écriture de « /home/my-home/.gimp-2.0/themerc » INIT: gimp_initialize
INIT: gimp_real_initialize
INIT: gui_initialize_after_callback
INIT: gimp_restore
INIT: gui_restore_callback
gimp: fatal error: Erreur de segmentation
Any suggestion ?
Thanks, Luc.
2004-11-16 12:39:36 UTC (over 20 years ago)
Luc Novalès writes:
The header is logo-pixbuf.h which is supposed to be generated in the gimpressionist source directory. Try 'make logo-pixbuf.h' in the gimpressionist directory.
Luc Novalès
2004-11-16 16:58:42 UTC (over 20 years ago)
Sven Neumann a écrit :
Luc Novalès writes:
Thanks for this reply.
make logo-pxbuf.h generates an error with this command
gdk-pixbuf-csource --raw --name=logo_data > logo-pixbuf.h
If I change manually to gdk-pixbuf-csource --raw --name=logo_data logo.png > logo-pixbuf.h
(logo.png is the only image in this directory), logo-pixbuf.h is generated, compilation and install are ok, but execution abort with segmentation fault just after tools options load splash screen.
log is :
-------------------------------------- 16:38 49 -> source mon_gimp_debug
Lecture de « /usr/local/etc/gimp/2.0/gimprc » Lecture de « /home/me/.gimp-2.0/gimprc » gimp_composite: use=yes, verbose=no
Processor instruction sets: -mmx -sse -sse2 -3dnow -altivec -vis Ajout du thème « Default » (/usr/local/share/gimp/2.0/themes/Default) Ajout du thème « Small » (/usr/local/share/gimp/2.0/themes/Small) Écriture de « /home/me/.gimp-2.0/themerc » INIT: gimp_initialize
INIT: gimp_restore
gimp: fatal error: Erreur de segmentation --------------------------------------
Note : there is no errors errors in config.log at plugins section :
config.status:1107: creating plug-ins/gflare/gflares/Makefile config.status:1107: creating plug-ins/gfli/Makefile config.status:1107: creating plug-ins/gimpressionist/Makefile config.status:1107: creating plug-ins/gimpressionist/Brushes/Makefile config.status:1107: creating plug-ins/gimpressionist/Paper/Makefile config.status:1107: creating plug-ins/gimpressionist/Presets/Makefile config.status:1107: creating plug-ins/help/Makefile config.status:1107: creating plug-ins/helpbrowser/Makefile ...
Luc.
