converting to CMYK
11 of 11 messages available
converting to CMYK Serrianne, Karen 24 May 16:32
  converting to CMYK Alexandre Prokoudine 24 May 16:59
   converting to CMYK Rick Strong 24 May 17:23
    converting to CMYK Patrick Shanahan 24 May 18:25
     converting to CMYK Rick Strong 24 May 18:49
      converting to CMYK Patrick Shanahan 24 May 20:30
       converting to CMYK Partha Bagchi 24 May 20:52
        converting to CMYK Patrick Shanahan 24 May 22:19
         converting to CMYK Partha Bagchi 24 May 22:29
          converting to CMYK Rick Strong 24 May 22:58
    converting to CMYK Jernej Simončič 25 May 06:33
Serrianne, Karen
2016-05-24 16:32:49 UTC (over 8 years ago)
converting to CMYK
Can this program convert RGB to CMYK?
Also, can images be saved as tiffs?
2016-05-24 16:59:46 UTC (over 8 years ago)
converting to CMYK
24 мая 2016 г. 19:40 пользователь "Serrianne, Karen" написал:
Yes, with http://cue.yellowmagic.info/softwares/separate-plus/
Yes, via File -> Export.
Alex
Rick Strong
2016-05-24 17:23:28 UTC (over 8 years ago)
converting to CMYK
Re: http://cue.yellowmagic.info/softwares/separate-plus/ It says WIN 32. Will this run on a WIN 64 platform?
Thanks, Rick
Patrick Shanahan
2016-05-24 18:25:34 UTC (over 8 years ago)
converting to CMYK
* Rick Strong [05-24-16 13:25]:
Simple to determine. Try and report to us.
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
Rick Strong
2016-05-24 18:49:42 UTC (over 8 years ago)
converting to CMYK
Am moving shortly. I think I'll wait. R
-----Original Message-----
Sent: Tuesday, May 24, 2016 2:25 PM To: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] converting to CMYK
Patrick Shanahan
2016-05-24 20:30:06 UTC (over 8 years ago)
converting to CMYK
* Rick Strong [05-24-16 14:50]:
-----Original Message----- From: Patrick Shanahan Sent: Tuesday, May 24, 2016 2:25 PM To: gimp-user-list@gnome.org Subject: Re: [Gimp-user] converting to CMYK
Simple to determine. Try and report to us. --
(paka)Patrick Shanahan Plainfield, Indiana, USA @ptilopteri http://en.opensuse.org openSUSE Community Member facebook/ptilopteri http://wahoo.no-ip.org Photo Album: http://wahoo.no-ip.org/gallery2 Registered Linux User #207535 @ http://linuxcounter.net _______________________________________________ gimp-user-list mailing list
well, it would probably take 10 minutes or so.
Partha Bagchi
2016-05-24 20:52:59 UTC (over 8 years ago)
converting to CMYK
So why don't you find out yourself? :)
@ptilopteri
facebook/ptilopteri
well, it would probably take 10 minutes or so. --
Patrick Shanahan
2016-05-24 22:19:06 UTC (over 8 years ago)
converting to CMYK
* Partha Bagchi [05-24-16 16:53]:
@ptilopteri
facebook/ptilopteri
if I was interested, and found it necessary, I would, but not so. The OP was and it is a simple test and really not deserving of list traffic, imnsho.
Would YOU post that type of question here? If the OP was capable of installing the software on his computer, *should* he not be capable of answering his own question? Is *no-one* capable or responsible any more?
Partha Bagchi
2016-05-24 22:29:34 UTC (over 8 years ago)
converting to CMYK
Then you could have simply ignored the question and moved on instead of ranting.
24,
@ptilopteri
facebook/ptilopteri
List address: gimp-user-list@gnome.org List membership:
List archives: https://mail.gnome.org/archives/gimp-user-list
@ptilopteri
facebook/ptilopteri
-- (paka)Patrick Shanahan Plainfield, Indiana, USA @ptilopteri http://en.opensuse.org openSUSE Community Member facebook/ptilopteri http://wahoo.no-ip.org Photo Album: http://wahoo.no-ip.org/gallery2 Registered Linux User #207535 @ http://linuxcounter.net _______________________________________________ gimp-user-list mailing list
Rick Strong
2016-05-24 22:58:38 UTC (over 8 years ago)
converting to CMYK
Let's all climb down, OK?
Breathe deeply, say "OOOOMMMM" and celebrate life. Or not. Your choice.
Life is short. Goodbye.
R
Jernej Simončič
2016-05-25 06:33:37 UTC (over 8 years ago)
converting to CMYK
If it doesn't, please report it as a bug (against GIMP) - 64-bit GIMP should be able to use 32-bit plug-ins.
< Jernej Simončič ><><><><>< http://eternallybored.org/ >
