Need help with transparency
Need help with transparency acctingman 20 May 04:33
  Need help with transparency Joseph A Nagy Jr 20 May 18:33
   Need help with transparency Steve Kinney 20 May 19:39
    Need help with transparency acctingman 21 May 02:30
     Need help with transparency Rick Strong 22 May 13:31
2016-05-20 04:33:14 UTC (almost 9 years ago)
Hello
Just downloaded GIMP yesterday and I need help with transparency
In the attachment, the little open area (that is white) I need it to be transparent so I can see another numbered dial that it will go on top of.
I know nothing about image editing, so this is a big request and more than happy and willing to do my homework.
Could someone break down how to make that little area transparent (while keeping all the icons and lettering on the dial remain white)?
Thank you
Joseph A Nagy Jr
2016-05-20 18:33:01 UTC (almost 9 years ago)
On 05/19/2016 23:33, acctingman wrote:
Hello
Thank you
Attachments: * http://www.gimpusers.com/system/attachments/245/original/base.png
Use the cut tool to remove that section, or the eraser tool to make to erase the color and leave a transparent section.
original: http://joseph-a-nagy-jr.us/images/tech-support/gimp-help/01.base.png
example modification using eraser tool: http://joseph-a-nagy-jr.us/images/tech-support/gimp-help/01.base-example.png
hth
Sincerely,
Joseph A. Nagy, Jr.
Owner, Trinity Electrical & Handyman Services
2016-05-20 19:39:23 UTC (almost 9 years ago)
Hello
Thank you
And make sure the image layer you are working on has an alpha channel, which enables transparency i the layer. Find your Layers dialog dock (it's the open tab in "number four" in the illustration on this page: http://docs.gimp.org/2.8/en/gimp-concepts-main-windows.html ). Right click on the layer thumbnail, and look for "Add Alpha Channel" in the menu that opens. If it's grayed out, no worries, there's already an alpha channel for that layer. If it's not grayed out, select it to add an alpha channel.
Then, anything you "erase" or "delete" from the layer will become transparent, rather than the current background color as set in the main toolbox (white by default).
:o)
Steve
2016-05-21 02:30:34 UTC (almost 9 years ago)
So, this what I ended up with.....
I had the white area selected with "fuzzy tool"....it was highlighted....clicked the white area......then used "Bucket fill tool"........then I set the affected area to Fill whole selection" and clicked inside that white area....it turned it black....saved it the area was black.....not transparent
Where did I go wrong?
Thanks
Rick Strong
2016-05-22 13:31:13 UTC (almost 9 years ago)
You can't "fill" an area with transparency.
- Add a transparent layer as described by Steve Kinney:
"... make sure the image layer you are working on has an alpha channel, which enables transparency i the layer. Find your Layers dialog dock (it's the open tab in "number four" in the illustration on this page: http://docs.gimp.org/2.8/en/gimp-concepts-main-windows.html ). Right click on the layer thumbnail, and look for "Add Alpha Channel" in the menu that opens. If it's grayed out, no worries, there's already an alpha channel for that layer. If it's not grayed out, select it to add an alpha channel.
Then, anything you "erase" or "delete" from the layer will become transparent..."
- Select your white area. - Delete it and you should see the transparency "checkerboard" show up. - Save your image or put it on top of whatever you want to show through.
Hope that helps, Rick
-----Original Message----- From: acctingman
Sent: Friday, May 20, 2016 10:30 PM
To: gimp-user-list@gnome.org
Subject: [Gimp-user] Need help with transparency
Thanks
Attachments: * http://www.gimpusers.com/system/attachments/246/original/base.png
acctingman (via www.gimpusers.com/forums)
