Problem with Crashing after adding more brushes
4 of 5 messages available
1072047327.6938042.14622419... 03 May 02:19
  Problem with Crashing after adding more brushes Wentlyana Brôtelîn 03 May 02:19
   Problem with Crashing after adding more brushes Ofnuts 03 May 07:05
   Problem with Crashing after adding more brushes Patrick Shanahan 03 May 13:37
    Problem with Crashing after adding more brushes Michael Natterer 03 May 15:05
Wentlyana Brôtelîn
2016-05-03 02:19:13 UTC (almost 9 years ago)
I have GIMP version 2.8.10 on my laptop running Windows 10I have been trying to add more brushes, however, when I do either GIMP won't completely load (usually at the point where it is updating tag cache) or when I go to start a NEW project it comes up that it has stopped working and Windows is checking for solutions and then shuts down.  If I remove the brushes from the GIMP brushes folder it works again. I just don't understand why it would keep crashing. I hope you may have heard of this previously and might know of a solution. Thanks.
2016-05-03 07:05:43 UTC (almost 9 years ago)
How many brushes did you add?
Patrick Shanahan
2016-05-03 13:37:56 UTC (almost 9 years ago)
* Wentlyana Brteln [05-03-16 09:33]:
just a guess, perhaps you have a bad brush. Try removing half, if doesn't crash, add another 1/4 (half of what is left) until you determine which is bad.
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
Michael Natterer
2016-05-03 15:05:22 UTC (almost 9 years ago)
On Tue, 2016-05-03 at 09:37 -0400, Patrick Shanahan wrote:
* Wentlyana Brôtelîn [05-03-16 09:33]:
Thanks.
bad.
And when you have found the bad brush, please open a bug and attach the brush file so the crash can be fixed.
Regards, --Mitch
