Gimp 2.8 erase to transparent doesn't work in Win 10
Gimp 2.8 erase to transparent doesn't work in Win 10 jalea148 24 Mar 15:29
  Gimp 2.8 erase to transparent doesn't work in Win 10 Richard 27 Mar 01:36
2016-03-24 15:29:44 UTC (about 9 years ago)
Works fine in Win 7.
Opened new with background transparent. in layers alpha to selection. imported image to layer; set alpha to selection. made selection and erased. area filled with background color.
Richard
2016-03-27 01:36:20 UTC (about 9 years ago)
Date: Thu, 24 Mar 2016 16:29:44 +0100 From: forums@gimpusers.com
To: gimp-user-list@gnome.org
CC: notifications@gimpusers.com
Subject: [Gimp-user] Gimp 2.8 erase to transparent doesn't work in Win 10
Works fine in Win 7. Opened new with background transparent. in layers alpha to selection. imported image to layer; set alpha to selection. made selection and erased. area filled with background color.
jalea148 (via www.gimpusers.com/forums)
That last part, "area filled with background color", is a telltale characteristic of not actually having an alpha channel on the image when you did the erase ... did you double-check that? Because if your steps are correct then something else must have happened along the way....
(I also run GIMP on Win 10 and have yet to find any problems.)
