debugging script-fu with list->string
debugging script-fu with list->string ugajin@talktalk.net 14 Mar 13:56
  debugging script-fu with list->string Kevin Cozens 20 Mar 02:55
   debugging script-fu with list->string ugajin@talktalk.net 20 Mar 11:17
    debugging script-fu with list->string Kevin Cozens 20 Mar 15:40
     debugging script-fu with list->string ugajin@talktalk.net 20 Mar 16:22
ugajin@talktalk.net
2016-03-14 13:56:07 UTC (over 9 years ago)
I believe Script-fu supports list->string but I may be mistaken. I am unable to get it to work. E.g. (gimp-message (list->string '(0 0 0) )) returns Error: ( : 2) string-set!: argument 3 must be: character
Both string-append and number->string work OK.
Please can someone provide example syntax.
Thanks
-u
Kevin Cozens
2016-03-20 02:55:09 UTC (over 9 years ago)
list->string is defined in the script-fu.init file. It takes a list of characters and returns a newly allocated string from formed form the characters in the list.
This is in accordance with the R5RS document (see page 30).
Cheers!
Kevin.
http://www.ve3syb.ca/           |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172      | the mouth-breathers, and that's why we're
                                 | powerful!"
#include  |             --Chris Hardwick
ugajin@talktalk.net
2016-03-20 11:17:24 UTC (over 9 years ago)
That is what I thought. Clearly something is wrong, but I am unable to identify the error. How, do I pass in a list of characters? GIMP complains when I try to pass in a list object. I have tried everything, I can think of.
Thanks.
----Original Message----
Date: 20/03/2016 02:55
To:
Subj: Re: [Gimp-user] debugging script-fu with list->string
am
of
-- Cheers!
Kevin.
distract
we're
| powerful!"
#include | --Chris Hardwick _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
List archives: https://mail.gnome.org/archives/gimp-user-list
Kevin Cozens
2016-03-20 15:40:10 UTC (over 9 years ago)
Oops... I meant to send this to the list.
You provided a list but it was a list of numbers, not characters. To create a list of characters you would use
(gimp-message (list->string '(#\H #\e #\l #\l #\o #\!)))
Characters are written as #\ followed by a the character you want, or by #\ and the name of a character (ie. space, or newline).
For some additional information you can look in the R5RS under section 6.3.4 on page 28.
There is a minor error in the printing of characters that I need to fix. It shows them as "#\x" instead of just "#\". I also just had a thought that this information should be put in to some document about Script-Fu basics.
Cheers!
Kevin.
                                 | powerful!"
ugajin@talktalk.net
2016-03-20 16:22:29 UTC (over 9 years ago)
Ah!
Screwed that completely, didn't I? I had (wrongly) thought that list-
string, would return any old data list values to the error console,
and more easily than how I am currently doing it. Fool that I am!
Thanks, again!
-u
Date: 20/03/2016 15:40
To: "gimp-user"
pass
create
a list of characters you would use (gimp-message (list->string '(#\H #\e #\l #\l #\o #\!)))
by #\
6.3.4
on page 28.
fix. It
that
basics.
Cheers!
Kevin.
distract
we're
| powerful!"
