gimp-drawable-curves-spline
gimp-drawable-curves-spline Maurizio Loreti 24 Feb 15:16
  gimp-drawable-curves-spline Kevin Payne 24 Feb 15:29
  gimp-drawable-curves-spline Joao S. O. Bueno 24 Feb 16:00
Maurizio Loreti
2016-02-24 15:16:43 UTC (almost 9 years ago)
Hello -
I am using GIMP 2.9.3 from Partha’s Place, on a Mac running OS X; from time to time I use a scheme plugin found in the gimpfx-foundry distribution (http://gimpfx-foundry.sourceforge.net) called "salonen-vivid-saturation.scm”. And, yes, I understand that gimpfx-foundry is unmaintained since ?2008? - however that scheme procedure has always worked well for me up to GIMP 2.8.
With GIMP 2.9 I get al alert saying that gimp-curves-spline (called from line 63 in the .scm procedure) is obsolete, and replaced now by gimp-drawable-curves-spline. The procedure however works; but I know some scheme and I would like to edit the .scm file in order to call gimp-drawable-curves-spline - but I cannot find on the Internet the synopsis for that new function.
The synopsis for the old one is: gimp-curves-spline (drawable, channel, num_points, control_pts)
Can some kind soul tell me how gimp-drawable-curves-spline must be called?
Maurizio Loreti   -   Maurizio.Loreti@gmail.com
Kevin Payne
2016-02-24 15:29:47 UTC (almost 9 years ago)
If you use the procedure-browser (at GIMP menu Help>>Procedure Browser) it shows the parameters required (which appear to be mostly the same, other than the control points have changed from being INT to FLOAT)
Kevin
Question for developers: Can you please make it possible to copy the text in the Procedure Browser for situations such as these.
Sent: 24 February 2016 15:16
To: gimp-user-list@gnome.org
Subject: [Gimp-user] gimp-drawable-curves-spline
Hello -
I am using GIMP 2.9.3 from Parthas Place, on a Mac running OS X; from time to time I use a scheme plugin found in the gimpfx-foundry distribution (http://gimpfx-foundry.sourceforge.net) called "salonen-vivid-saturation.scm.  And, yes, I understand that gimpfx-foundry is unmaintained since ?2008? - however that scheme procedure has always worked well for me up to GIMP 2.8.
Joao S. O. Bueno
2016-02-24 16:00:39 UTC (almost 9 years ago)
You can see the definition of all the avaliable functions on GIMP's PDB using the "Help->PDB Browser" menu option from inside GIMP
On 24 February 2016 at 12:16, Maurizio Loreti wrote:
Hello -
-- Maurizio Loreti - Maurizio.Loreti@gmail.com
