Greeting card
Greeting card MrBryant71 07 Dec 21:00
  Greeting card Akkana Peck 09 Dec 01:10
   Greeting card MrBryant71 09 Dec 15:01
2015-12-07 21:00:41 UTC (over 9 years ago)
Greeting card
Hello everyone! I was wondering if any of my fellow gimp user can tell me how to create greeting cards using gimp 2.8? Thank you in advance!
Akkana Peck
2015-12-09 01:10:21 UTC (over 9 years ago)
Greeting card
MrBryant71 writes:
I wrote a greeting card tutorial back in 2009: http://www.linuxplanet.com/linuxplanet/tutorials/6925/1/ Old, but I don't think much has changed. The important points are:
1. Make a canvas the size of your printed sheet -- US Letter or A9 or whatever; then think about how the paper will be folded, and put your image on the correct half.
2. Make sure you understand the difference between pixel resolution and print size, so you don't start with a small image that's going to be fuzzy when you print it.
The rest is just up to your creativity and GIMP skills. Have fun!
...Akkana
2015-12-09 15:01:18 UTC (over 9 years ago)
Greeting card
MrBryant71 writes:
...Akkana
Thanks for your help I will definitely apply what you've just shared with me! I am excited!
