Elementary question for an old mapmaker
5 of 6 messages available
1916732170.2286099.14486456... 27 Nov 20:57
  Elementary question for an old mapmaker petershea1@comcast.net 27 Nov 17:42
   Elementary question for an old mapmaker Jernej Simončič 27 Nov 22:47
   Elementary question for an old mapmaker J. Leslie Turriff 29 Nov 09:00
   Elementary question for an old mapmaker Ross Martinek 29 Nov 19:39
    Elementary question for an old mapmaker Americo Gobbo 29 Nov 20:18
2015-11-27 17:42:28 UTC (about 9 years ago)
I've just finished hand drawing about fifty simple, small (8.5 X 11) maps in a two-month period. I'm hoping for an easier way, without going broke or making my head explode.
I've read a summary of the GIMP drawing program, but it is not clear to me, if you can import images such as scans, or Google Earth. Google maps, etc. Can you import an image and trace from it, or does one only draw original subjects? I assume it has wide typographic ability for font and sizes??
Thanks,
Peter
Jernej Simončič
2015-11-27 22:47:14 UTC (about 9 years ago)
GIMP is primarily a bitmap editor - you'll probably find Inkscape better suited for tracing.
begin  .sig
< Jernej Simončič ><>◊<>< jernej|s-ng at eternallybored.org >
end
J. Leslie Turriff
2015-11-29 09:00:38 UTC (about 9 years ago)
If you want to load output from a scanner or a camera into Gimp, use File -> Create...
Thanks,
Peter
A Caution to Everybody
	Consider the Auk;
	Becoming extinct because he forgot how to fly, and could only walk.
	Consider man, who may well become extinct
	Because he forgot how to walk and learned how to fly before he thinked.
-- Ogden Nash
Ross Martinek
2015-11-29 19:39:42 UTC (about 9 years ago)
Hello Peter,
Yes, GIMP will import most graphics files, and you can use layers to trace over them. It does have a wide typographic library, and appears to recognize all the fonts installed on your system. I am working with GIMP and a map I originally sketched in Adobe Photoshop (a software I have abandoned completely in favor of GIMP.)
However, you should, as others recommend, investigate Inkscape (as I intend to do in the near future). If you are on a Mac OS, take a look at http://www.mapdiva.com/ortelius/.
All of these programs have fairly steep learning curves if you are not familiar with CG, however, the time spent is ultimately worth it.
Ross
Thanks,
Peter
Americo Gobbo
2015-11-29 20:18:01 UTC (about 9 years ago)
in 2013 I had the opportunity to put in praxis a process to paint a big map (250x190 cm) using GIMP and MyPaint. You can see my approach to this work... but is in Portuguese... but I think that the google translate can help a bit. The posts about this work and process are: http://forksanddrills.blogspot.com/2013/05/fazendo-mapas-enormes-com-mypaint-e-o.html http://forksanddrills.blogspot.com/2013/06/cartografia.html
Americo
On Sun, Nov 29, 2015 at 5:39 PM, Ross Martinek wrote:
Hello Peter,
Ross
