resize question
resize question Serge 27 Oct 13:35
resize question Bob Long 27 Oct 14:16
Serge
2004-10-27 13:35:20 UTC (over 20 years ago)
resize question
Hi
Used to work with photoshop, for instance when i want to take someone's hand in one picture and to put it in another one, i chose my selection , copied it and pasted it into the second picture, and then I could resize it [bigger or smaller], transform it to ajust it to my wills. How can i do it with gimp? The resize , transform tool is for the whole layer and not for the selection itself..I suppose i am missing something..
Thank for your help
Bob Long
2004-10-27 14:16:04 UTC (over 20 years ago)
resize question
I did this in 2.0.5 (for Windows):
Opened two images. Selected something from first image. Edit|Copy. In second image, Edit|Paste. That creates a pasted layer. Select the Scale tool (or Shift-T). You should be able to drag the handles around the pasted layer to scale it. You may have to ensure the "Scale Options" has "Transform Layer" selected in the "Affect:" selection.
Bob Long
