Transparent Gif
Transparent Gif Pau Cabot 21 Oct 22:35
  Transparent Gif Carol Spears 22 Oct 03:30
   Transparent Gif Pau Cabot 24 Oct 13:09
    Transparent Gif olivier ripoll 24 Oct 16:29
     Transparent Gif Pau Cabot 24 Oct 19:44
    Transparent Gif Carol Spears 24 Oct 17:35
Pau Cabot
2004-10-21 22:35:10 UTC (over 20 years ago)
Transparent Gif
Is there an easy way to make transparent gifs with Gimp 2.0? I found this recipe, but I couldn't understand it completely:
http://hs.riverdale.k12.or.us/~pnelson/web_design/transparent.html
(I am a newbie)
Thanks, Pau.
Carol Spears
2004-10-22 03:30:07 UTC (over 20 years ago)
Transparent Gif
(I am a newbie)
actually, that was a fairly clear little how to. right clicking on the image will show you the same menu options nelson mentioned.
Pau Cabot
2004-10-24 13:09:06 UTC (over 20 years ago)
Transparent Gif
En/na Carol Spears ha escrit:
(I am a newbie)
I use Gimp 2.0 and i do not have the options pnelson says in his step 2.
Could someone help me?
Thanks, Pau.
olivier ripoll
2004-10-24 16:29:27 UTC (over 20 years ago)
Transparent Gif
instead of:
>> Layers >> Add alpha channel
it is
>> Layer >> Transparency >> Add alpha channel
Thanks, Pau.
Olivier.
Carol Spears
2004-10-24 17:35:09 UTC (over 20 years ago)
Transparent Gif
oh, i see. some of the menu places have changed between gimp and gimp2. The "Add Alpha Channel" option in now found under Layer -->Transparency.
you can also right click on the layers dialog face to the left of the thumbnail of the layer you are working on. this brings up a menu with the same options (and a few more).
Pau Cabot
2004-10-24 19:44:52 UTC (over 20 years ago)
Transparent Gif
En/na olivier ripoll ha escrit:
instead of:
it is
I couldn't do this. The action is not permitted.
I finally did it changing step 1: Instead of Image >> Mode >> RGB, I did: Image >> Flatten image. And this way, it works!
Thank you everybody, Pau.
