Help
8 of 8 messages available
Help Liparis 18 Sep 13:23
  Help Shlomi Fish 19 Sep 10:17
   Help Liparis 19 Sep 12:13
  Help Michael Schumacher 19 Sep 11:47
   Help Liparis 19 Sep 12:17
  Help Kevin Cozens 19 Sep 12:00
   Help Liparis 19 Sep 12:20
    Help Partha Bagchi 21 Sep 22:33
2015-09-18 13:23:16 UTC (over 9 years ago)
Help
I've just downloaded the latest Gimp for the first time. However, I'm very frustrated. All I get when I open Gimp is a big empty box, no tools of any sort. It looks nothing like the screen shots in the manual! Along the top of the box are the menus but that's all. When I open a photograph in it, it appears as a small thumbnail that I'm unable to do anything with. Also, by default, when looking for images, it is set to recognise "All Files" but it doesn't do so, I have to select a different file then choose all files again to see the images. Hope you can help, I'm becoming extremely frustrated! Many thanks.
Shlomi Fish
2015-09-19 10:17:16 UTC (over 9 years ago)
Help
Hi Liparis,
1. I hope you downloaded GIMP from http://www.gimp.org/downloads/ .
2. What is your system: operating system, version, CPU, CPU architecture, versions, etc.
3. Can you provide a screenshot of your screen when GIMP is running? You can use http://imgur.com/ to share it online (or any other site that does not require JavaScript to be enabled for its images to be viewed).
4. Did you try running GIMP in a new operating system user account?
Shlomi Fish
Shlomi Fish       http://www.shlomifish.org/
List of Text Processing Tools - http://shlom.in/text-proc
SGLau: By the way, herr Frog: it is not that hard to be green.
    — http://is.gd/htmOCv
Please reply to list if it's a mailing list post - http://shlom.in/reply .
2015-09-19 11:47:13 UTC (over 9 years ago)
Help
The docks are likely just hidden - try the Tab key when the image window has the focus, or use the Windows->Hide docks menu entry.
Kevin Cozens
2015-09-19 12:00:01 UTC (over 9 years ago)
Help
That sounds like the typical problem of opening a RAW file from a digital camera when you don't have a plug-in to handle the RAW file format.
I think you need either the dcraw or ufraw plug-in for GIMP in order for it to be able to open the photograph files. Without knowing which operating system you are using I can't offer more specific help.
Cheers!
Kevin.
http://www.ve3syb.ca/           |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172      | the mouth-breathers, and that's why we're
                                 | powerful!"
#include  |             --Chris Hardwick
2015-09-19 12:13:04 UTC (over 9 years ago)
Help
Hi Liparis,
versions, etc.
Shlomi Fish
HI Shlomi,
First of all, I should say I'm not exactly PC savvy when it comes to technical stuff. Yes, I read all the pitfalls about downloading any programs and can confirm that I downloaded from http://www.gimp.org/downloads/ . My operating system is Windows 10 but I'm afraid I don't know what the CPU version or architecture is. I've attached a screenshot.
Hope this helps.
Liparis
2015-09-19 12:17:22 UTC (over 9 years ago)
Help
Hi Michael,
I've tried your suggestions but no joy. Liparis
2015-09-19 12:20:34 UTC (over 9 years ago)
Help
Hi Kevin,
Many thanks. Yes, I've been opening RAW files. I tried again with a JPG and find that it opens fine. I suppose I need to find a plug-in for RAW files now? Thanks,
Bill
Partha Bagchi
2015-09-21 22:33:35 UTC (over 9 years ago)
Help
I suppose I can tell you that you can download GIMP builds from my Website (www.partha.com) where the builds do not cause such issues. However, my builds are not officially sanctioned by the GIMP developers but I am not in the habit of producing malwares or viruses.
Hi Kevin,
Bill
Liparis (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
