how to cut both the inside and outside of an image
how to cut both the inside and outside of an image chants 16 Sep 08:23
  how to cut both the inside and outside of an image Shlomi Fish 17 Sep 07:33
2015-09-16 08:23:08 UTC (over 9 years ago)
Hi
I am trying to cut and paste an image if a ring ...there is an inner edge and an outer edge.. and obviously the part in the middle should be cut away... I have tried to do this, but when i click enter , the dancing ants dont appear
1. How do i move from the outside to the inside without cutting accross the ring 2. How do i do this task
3 How do i switch the scissor tool off, since it transfers to the new layer 4.In general , how do you switch the tools off
Thanks
Shlomi Fish
2015-09-17 07:33:20 UTC (over 9 years ago)
Hi chants,
On Wed, 16 Sep 2015 10:23:08 +0200 chants wrote:
Hi
You can remove an inner selection from an outer selection - see "subtract mode" here: http://docs.gimp.org/en/gimp-tools-selection.html . You may also find the channels feature more convenient for you - http://docs.gimp.org/en/gimp-channel-dialog.html .
Thanks
Shlomi
Shlomi Fish       http://www.shlomifish.org/
Let’s talk about restores instead of backups - http://is.gd/WatQqu
Don't worry over what other people are thinking about you.  They're too
busy worrying over what you are thinking about them.
    — Unknown Source
Please reply to list if it's a mailing list post - http://shlom.in/reply .
