GdkPixbuf problem
GdkPixbuf problem Matthew H. Plough 16 Oct 00:32
  GdkPixbuf problem Sven Neumann 22 Oct 01:01
Matthew H. Plough
2004-10-16 00:32:02 UTC (over 20 years ago)
GdkPixbuf problem
Hi everyone --
At
http://developer.gnome.org/doc/API/2.0/gdk-pixbuf/gdk-pixbuf-gdk-pixbuf.html , the GDK developer's documentation specifies the bits-per-sample property as follows:
The number of bits per sample.
Allowed values: [1,16]
Default value: 8
However, I get the following error when I try to allocate a pixbuf with 16 bits per sample in Windows 2000:
(rawtools:372): GdkPixbuf-CRITICAL **: file gdk-pixbuf.c: line 261 (gdk_pixbuf_n
ew): assertion `bits_per_sample == 8' failed
Is this a known issue? If so, when will it be fixed?
Matt
2004-10-22 01:01:18 UTC (over 20 years ago)
GdkPixbuf problem
"Matthew H. Plough" writes:
Default value: 8
This is known. GdkPixbuf does only support 8 bits per color channel. This is however completely off-topic here since GdkPixbuf if not developed or maintained by the GIMP developers. Please check bugzilla.gnome.org, product gtk+, and file an enhancement request if there isn't one already.
