removing tint from a picture
removing tint from a picture John Broyles 29 Jul 18:59
  removing tint from a picture s.kortenweg 30 Jul 08:46
   removing tint from a picture Steve Kinney 30 Jul 16:12
  removing tint from a picture Liam R E Quin 30 Jul 16:34
   removing tint from a picture akovia 09 Aug 15:30
John Broyles
2015-07-29 18:59:40 UTC (over 10 years ago)
I recently converted some old slides to digital pictures. Unfortunately some of the older slides have developed a pink tint, probably from age. Can I remove this tint in the digital pictures using Gimp? I looked at color level but could not understand whether this would solve my problem or not.
Thanks,
John
s.kortenweg
2015-07-30 08:46:40 UTC (over 10 years ago)
You can use the restore filter.
Go to www.gimpusers.com/news/00237-exeptional-plugin-photo-restore
there you find the instructions to download and instal the filter. It works almost very fine.
Good luck with it.
Simon.
Op 29-07-15 om 20:59 schreef John Broyles:
Thanks,
John _______________________________________________ gimp-user-list mailing list
2015-07-30 16:12:36 UTC (over 10 years ago)
Well heck. That filter looks amazing, but on the first try here it failed in a major way: First it threw error messages and appeared to exit, then it ate so much CPU and memory that I had to reboot the machine to get rid of it. I am using GIMP 2.8.10 on Linux Mint 17, AMD 64. Apparently the plugin was written for GIMP 2.6, and an earlier version of Python than I have installed, so for now I will blame the problem on compatibility issues with GIMP and/or Python.
What I usually do to remove tints from images is:
1) Open the image and use the eyedropper to pick a sample of the color I want to suppress.
2) Open the color selection dialog and set the picked color to maximum saturation/value.
3) Make a new empty layer, fill it with the color in question and set its mode to Color.
4) Do Colors > Invert, to obtain a color that can cancel out the unwanted tint.
5) Set the transparency of the new layer to a low value, < 10%, and adjust until the best looking results are found.
6) Create a "new layer from visible" twice, set the mode of the new top layer to Overlay, and adjust its transparency until the best looking results are found.
That last step restores a lot of lost contrast and saturation to the image. Before this is done, the results look "foggy" because adding the color from the layer to the tinted layer below it replaces the unwanted color with unwanted gray. Increasing the contrast of the overlay layer may also be useful.
Results of this process are usually not as good as in the examples of the restore.py plugin's results, but so far I don't have a better way. Any suggestions?
:o)
Steve
Liam R E Quin
2015-07-30 16:34:13 UTC (over 10 years ago)
Two fairly easy ways -
(1) use Colour/Colour Balance (2) use Colour/Curves to raise green and blue
You can get a start on (2) with Colours->Levels and pressing auto; unfortunately this may lose a small amount of detail in highlights and shadows, but if before pressing OK you click on Edit in Curves (the exact labels and menu names may vary depending on your language and locale of course) you can move the curves slightly. For many applications levels/auto works magic.
Liam
Thanks,
John
akovia
2015-08-09 15:30:12 UTC (over 10 years ago)
Liam
Thanks,
John
Liam Quin - XML Activity Lead, W3C, http://www.w3.org/People/Quin/ Pictures from old books: http://fromoldbooks.org/ _______________________________________________ gimp-user-list mailing list
akovia
This is what I use and get great results.
https://www.youtube.com/watch?v=gr692iyYBUI
