Text tool problem
Text tool problem Balas Mark 14 Oct 11:18
  Text tool problem Sven Neumann 14 Oct 13:01
   Text tool problem Balas Mark 14 Oct 15:19
    Text tool problem olivier ripoll 14 Oct 19:29
  Text tool problem Geoffrey 14 Oct 15:03
Balas Mark
2004-10-14 11:18:47 UTC (about 21 years ago)
Text tool problem
Hi!
I have just started to use Gimp 2.0.5, under Mandrake Linux 10.0. I have a really serious problem with the text tool.
If I do the following:
1. Start Gimp 2. Create a new image
3. Select the text tool
4. Click on the new image
5. Start typing any text
Both the image window and Gimp closes without any warning after the first 1 to 3 letters. The text I type do not appear in the "word processing" window.
Thanks for any help in andvance.
Mark Balas
2004-10-14 13:01:14 UTC (about 21 years ago)
Text tool problem
Balas Mark writes:
It would probably help to start gimp from an xterm (or whatever terminal emulator you prefer) and check if there's any output on the console.
I guess that your problem is a somewhat broken font that causes problems with the libraries that handle fonts for GIMP. Does this happen with whatever font you choose? What versions of freetype and fontconfig are you using?
Geoffrey
2004-10-14 15:03:25 UTC (about 21 years ago)
Text tool problem
Balas Mark wrote:
Hi!
Long shot here, but was the 'word processing' window the current window? Or was it possible that GIMP was picking up what you were typing and took it as some command, say exit??
Balas Mark
2004-10-14 15:19:57 UTC (about 21 years ago)
Text tool problem
Hi!
The output is the following:
[trychydts@localhost trychydts]$ /usr/local/bin/gimp
(gimp:2212): GLib-GObject-WARNING **: invalid uninstantiatable type `' in cast to `GimpConfigInterface'
(gimp:2212): Gimp-Config-CRITICAL **: file gimpconfig-utils.c: line 300 (gimp_config_sync): assertion `GIMP_IS_CONFIG (src)' failed
(gimp:2212): GLib-GObject-CRITICAL **: file gobject.c: line 1319 (g_object_ref): assertion `G_IS_OBJECT (object)' failed
(script-fu:2213): LibGimpBase-WARNING **: script-fu: wire_read(): error Segmentation fault (core dumped)
I haven't tried all, beacause I have about 300 fonts installed, but it seems to be the case.
How could I find this out? (Sorry for being so amateur, but I switched to Linux only three months ago.)
Thanks,
Mark Balas
olivier ripoll
2004-10-14 19:29:46 UTC (about 21 years ago)
Text tool problem
Balas Mark wrote:
Hi!
Go to the mandrake control center, package category, and launch the remove package tool. There you can search for "fontconfig" and "freetype", and it should return you the name of the rpm packages installed on your system.
DO NOT UNINSTALL THEM. just note the name of the packages
On a Mandrake 10.0, you should have: fontconfig-2.2.1-7mdk.i586.rpm
libfontconfig1-2.2.1-7mdk.i586.rpm
freetype-1.3.1-21mdk.i586.rpm
freetype-tools-1.3.1-21mdk.i586.rpm
freetype2-tools-2.1.7-1mdk.i586.rpm
libfreetype6-2.1.7-4mdk.i586.rpm
also, there are packages called gimp-freetype (don't ask me what they do, I think it is the freetype plugin, so there are not relevant) gimp-freetype-0.2-3mdk.i586.rpm
gimp2-freetype-0.5-3mdk.i586.rpm
Thanks,
Mark Balas
Just as a data point, I have gimp 2.0.5 installed on my Mandrake 10.0
Could you also give the version of your gtk2 package called libgtk+2.0-versionnumber-numbermdk.i586.rpm On an original mdk 10.0, it is 2.2.4, which I am not sure is enough for gimp 2.0.5.
Best regards,
Olivier.
PS: there are some rpm of gimp 2.0.3 here: http://wwwra.informatik.uni-rostock.de/~waschk/Mandrake/10.0/
