Script-fu paths example
Script-fu paths example Philip Stubbs 12 Oct 10:31
  Script-fu paths example Joao S. O. Bueno Calligaris 12 Oct 16:51
Philip Stubbs
2004-10-12 10:31:38 UTC (about 21 years ago)
Sorry if this is a newbie question, but I am one;-)
I am trying to write a script to generate our company logo. I need to programatically generate a path that I can convert to a selection. Does anybody have a simple example script-fu that generates a path that I can use for inspiration?
I can't seem to get me head round the path function in script-fu, however, if I see it being used in context, I should be able to adapt it to my purpose.
2004-10-12 16:51:28 UTC (about 21 years ago)
Hi there!
I've done it using Python-fu. The language is different than script-fu, but the function calls to the GIMP? PDB are just the same.
Check the scripts at http://hopey.nervo.org/~gwidion/gimp
These scripts were made for gimp-1.2.x , and I had not updated them because gimp-2.0 already does what the scripts do (mopstly). But I believe they might even run 8unmodified under gimp-2.0
Anyway, the path PDB is used there.
