problem with install GAP
| problem with install GAP | Muhamad Moghadam | 02 Jun 02:28 |
| problem with install GAP | Owen Cook | 02 Jun 04:57 |
| problem with install GAP | Alexandre Prokoudine | 02 Jun 12:22 |
| CAHw=+OSvXDLXTbLpLLg9jzytSz... | 02 Jun 14:44 | |
| problem with install GAP | Alexandre Prokoudine | 02 Jun 14:44 |
I try to install gap in fedora 22 and gimp 2.8.14
[user@dhcppc0 ~]$ cd /home/user/Downloads/gimp-gap-2.2.0
[user@dhcppc0 gimp-gap-2.2.0]$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... no
checking for cc... no
checking for cl... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
how can i fix this?
Sent: Tuesday, June 02, 2015 at 12:28 PM From: "Muhamad Moghadam"
To: gimp-user-list@gnome.org
Subject: [Gimp-user] problem with install GAPI try to install gap in fedora 22 and gimp 2.8.14
how can i fix this?
Install a C compiler, you probably need GCC, C++, do a yum search on those items.
Once you get those installed, rerun configure, and read carefully the next failure and install that as well, probably be autotools
Owen
configure: error: no acceptable C compiler found in $PATHhow can i fix this?
Yum is decommissioned in F22.
The right way now is to just run 'dnf builddep gimp'. This should install all prerequisites.
Alex
Actually, I've just thought:
Why are you trying to build GAP 2.2, when 2.7 is already available in Fedora?
https://apps.fedoraproject.org/packages/gimp-gap
'dnf install gimp-gap'
Alex
On Tue, Jun 2, 2015 at 5:37 PM, Muhamad Moghadam wrote:
I run dnf builddep gimp and than ./configure :
[root@dhcppc0 gimp-gap-2.2.0]# ./configure checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk
checking whether make sets $(MAKE)... yes checking whether to enable maintainer-specific portions of Makefiles... no checking for gcc... gcc
checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking for library containing strerror... none required checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes checking whether gcc accepts -g... (cached) yes checking for gcc option to accept ANSI C... (cached) none needed checking dependency style of gcc... (cached) gcc3 checking how to run the C preprocessor... gcc -E checking for egrep... grep -E
checking for ANSI C header files... yes checking for ranlib... ranlib
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for unistd.h... (cached) yes checking for bind_textdomain_codeset... yes checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking for GIMP... configure: error: Package requirements (gimp-2.0 >= 2.2.0 gimpui-2.0 >= 2.2.0 gimpthumb-2.0) were not met. Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix.Alternatively you may set the GIMP_CFLAGS and GIMP_LIBS environment variables
to avoid the need to call pkg-config. See the pkg-config man page for more details.On Tue, Jun 2, 2015 at 4:52 PM, Alexandre Prokoudine wrote:
Alex _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list List archives: https://mail.gnome.org/archives/gimp-user-list--
In God we Trust.
www.krtrucks.com
و لکن اکثرهم لا یعقلون
