building gimp-2.0.5 on Solaris 8
| building gimp-2.0.5 on Solaris 8 | Kenneth Simpson | 04 Oct 00:46 |
| building gimp-2.0.5 on Solaris 8 | Sven Neumann | 04 Oct 10:27 |
Hi - I'm trying to build gimp-2.0.5 on Solaris 8 with gtk+-2.4.10 and I'm encountering problem with the gfig plugin not compiling.
The compile error is enclosed.
Also, I noticed gfig-stock.c is including
#include "images/gfig-stock-pixbufs.h"
which is an empty file.
Any ideas?
Any help would be greatly appreciated.
-- Ken
make[4]: Entering directory `/domus1/gimp/src/gimp-2.0.5/plug-ins/gfig'
source='gfig-stock.c' object='gfig-stock.o' libtool=no \
depfile='.deps/gfig-stock.Po' tmpdepfile='.deps/gfig-stock.TPo' \
depmode=gcc /bin/bash ../../depcomp \
/usr/devtools/bin/gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../.. -DXTHREADS
-I/usr/gnome/include/gtk-2.0 -I/usr/gnome/lib/gtk-2.0/include
-I/usr/gnome/include/atk-1.0 -I/usr/gnome/include/pango-1.0
-I/usr/gnome/include -I/usr/gnome/include/freetype2 -I/usr/gnome/include/
glib-2.0 -I/usr/gnome/lib/glib-2.0/include -I/usr/gimp/include
-I/usr/gnome/include -I/usr/gimp/include -DGDK_MULTIHEAD_SAFE -DGTK_
MULTIHEAD_SAFE -g -O2 -Wall -c `test -f 'gfig-stock.c' || echo
'./'`gfig-stock.c
gfig-stock.c: In function `gfig_stock_init':
gfig-stock.c:93: `stock_bezier' undeclared (first use in this function)
gfig-stock.c:93: (Each undeclared identifier is reported only once
gfig-stock.c:93: for each function it appears in.)
gfig-stock.c:94: `stock_circle' undeclared (first use in this function)
gfig-stock.c:95: `stock_copy_object' undeclared (first use in this function)
gfig-stock.c:96: `stock_curve' undeclared (first use in this function)
gfig-stock.c:97: `stock_delete_object' undeclared (first use in this function)
gfig-stock.c:98: `stock_ellipse' undeclared (first use in this function)
gfig-stock.c:99: `stock_line' undeclared (first use in this function)
gfig-stock.c:100: `stock_move_object' undeclared (first use in this function)
gfig-stock.c:101: `stock_move_point' undeclared (first use in this function)
gfig-stock.c:102: `stock_polygon' undeclared (first use in this function)
gfig-stock.c:103: `stock_spiral' undeclared (first use in this function)
gfig-stock.c:104: `stock_star' undeclared (first use in this function)
gfig-stock.c:106: `stock_logo' undeclared (first use in this function)
make[4]: *** [gfig-stock.o] Error 1
make[4]: Leaving directory `/domus1/gimp/src/gimp-2.0.5/plug-ins/gfig'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/domus1/gimp/src/gimp-2.0.5/plug-ins/gfig'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/domus1/gimp/src/gimp-2.0.5/plug-ins'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/domus1/gimp/src/gimp-2.0.5'
make: *** [all] Error 2
"It is a capital mistake," Sherlock Holmes told Watson, "to theorize before one has data. One begins to twist facts to suit theories, instead of theories to suit facts."
Kenneth Simpson writes:
The file is generated, so if it is empty, something is wrong with your build setup. You probably got an error earlier that you didn't notice.
The file is generated using gdk-pixbuf-csource and the common cause of this problem is that the pixbuf loader modules aren't installed correctly. There should be a gdk-pixbuf.loaders file in the sysconf directory of your gtk+ installation that points to the installed pixbuf modules.
