Help Installing Resynthesizer Script / Heal Selection
2015-03-26 09:15:56 UTC (about 10 years ago)
Hi all
This is my first post.
I am running GIMP on Linux / Ubuntu (latest stable version of GIMP) and I just tried too install a script i.e. Resynthesizer Script / Heal Selection
I installed it following instructions from the Gimp registry site :
When I attempt to use heal selection :
Select --- Enhance ---- Heal Selection
I get a nice little dialog asking me to enter my params
I then click OK and get the following
a pop up error message box that reads
error: procedure not found Calling error for procedure 'gimp-procedural-db-proc-info': Procedure 'plug-in-resynthesizer' not found
Traceback (most recent call last): File "/usr/lib/gimp/2.0/python/gimpfu.py", line 699, in response dialog.res = run_script(params)
File "/usr/lib/gimp/2.0/python/gimpfu.py", line 361, in run_script return apply(function, params)
File "/home/phil/.gimp-2.8/plug-ins/plugin-heal-selection.py", line 148, in heal_selection pdb.plug_in_resynthesizer(timg, tdrawable, 0,0, useBorder, work_drawable.ID, -1, -1, 0.0, 0.117, 16, 500) error: procedure not found
My scripts are here
~/.gimp-2.8/plug-ins -rwxr-xr-x 1 root root 3153 Mar 26 00:15 plugin-heal-transparency.py -rwxr-xr-x 1 root root 6595 Mar 26 00:15 plugin-heal-selection.py -rwxr-xr-x 1 root root 6011 Mar 26 00:15 plugin-uncrop.py -rwxr-xr-x 1 root root 3262 Mar 26 00:15 plugin-resynth-sharpen.py -rwxr-xr-x 1 root root 3609 Mar 26 00:15 plugin-resynth-fill-pattern.py -rwxr-xr-x 1 root root 3303 Mar 26 00:15 plugin-resynth-enlarge.py -rwxr-xr-x 1 root root 7684 Mar 26 00:15 plugin-render-texture.py -rwxr-xr-x 1 root root 17194 Mar 26 00:15 plugin-map-style.py -rwxr-xr-x 1 root root 62838 Mar 26 00:18 resynthesizer -rwxr-xr-x 1 root root 53607 Mar 26 00:18 resynthesizer-gui
I am not the most geeky person in the world, but can find my way around the linux command line OK, albeit I am no Linux expert
Can anybody tell me what I've done wrong
Originally I had the scripts residing in usr/lib/gimp/2.0 (but I read they should be in the 2.8 directory). In fact the scripts are in both folders
MAny thanks in anticipation of your help
Phil
Alexandre Prokoudine
2015-03-27 15:53:13 UTC (about 10 years ago)
On Thu, Mar 26, 2015 at 12:15 PM, bwfcnottingham wrote:
My scripts are here
You copied them as root (superadministrator) user. Easiest way to fix it is to remove them with same privilegies, then copy as ordinary user.
Also, make sure they are executable. For that you can either run 'chmod +x ~/.gimp-2.8/plug-ins/*.py' or use file browser of your choice.
Alex
2015-03-27 17:50:44 UTC (about 10 years ago)
On 26/03/15 10:15, bwfcnottingham wrote:
Hi all
Traceback (most recent call last): File "/usr/lib/gimp/2.0/python/gimpfu.py", line 699, in response dialog.res = run_script(params) File "/usr/lib/gimp/2.0/python/gimpfu.py", line 361, in run_script return apply(function, params)
My scripts are here
In Ubuntu you can install the gimp-registry package from the repository. This will install a bunch of useful plugins including this one.
rich
2015-03-27 18:48:04 UTC (about 10 years ago)
bwfcnottingham gimpusers.com> writes:
ofnuts beats me to it again
I get a nice little dialog asking me to enter my params I then click OK and get the following a pop up error message box that reads
The heal-selection plugin is python and that will work whatever. It could be that the binary resynthesizer plug-in is the wrong 'flavour' 32 bit and should be 64 bit maybe or something else.
snip My scripts are here
~/.gimp-2.8/plug-ins -rwxr-xr-x 1 root root 3153 Mar 26 00:15 plugin-heal-transparency.py -rwxr-xr-x 1 root root 6595 Mar 26 00:15 plugin-heal-selection.py -rwxr-xr-x 1 root root 6011 Mar 26 00:15 snip
root is not the correct owner for files in your gimp profile ~/.gimp-2.8/ plugins.
phil should be in there as owner.
I think plug-ins should go in your Gimp profile. However if installed from a package, they will end up in /user... Not a good idea to have in both locations, AFAIK your Gimp profile takes precedence and that has incorrect permissions.
One way for Ubuntu (is this the worst user distro in the world?)
Get rid of all the previous stuff.
open a terminal to get a root prompt: sudo -i (then password) apt-getupdate
apt-get install gimp-plugin registry
screenshot: http://tinyurl.com/p3o8gbv
Unfortunately you get a whole load of other scripts and plugins, such is the price.. but you do get heal-selection in Filters -> enhance and you should see resynthesizer in Filters -> Map
2015-03-28 00:22:07 UTC (about 10 years ago)
Hi Everybody
Thanks for your valuable help and assistance.
I've fixed the problem (rather easily actually), I went for the option to install GIMP plugins (lots of them) from the Ubuntu software centre . I removed the files I dowloaded and then installed the plugins from the software centre. The filter works fine now. Internet forums are excellent , people freely offering to help and assist you. Have a great weekend everybody :)
Thanks again Phil :)
