Changing sky colour in Gimp 2.0.
On Mon, Sep 27, 2004 at 09:49:43PM +0100, Jenny Drake wrote:
I have a need to sometimes change the colour of a sky on a picture while
leaving the clouds unchanged.
In gimp 1.2 I do this by using the Decompose to Hue, Saturation and
Value function, then taking the Saturation, inverting the black to white
values and copying and pasting this to a layer mask on the original
image. This set the blue saturated clear sky to varying degrees of
transparency, depending on how deep the blue was, leaving the monochrome
clouds unchanged. A layer could then be placed behind with the desired
sky colour.
I now have Gimp 2.0 installed, but have not found a way of getting the
same results. There doesn't appear to be anything that can turn a
picture into a grey scale based on colour saturation.
Is there a way of doing this, or another way of changing just the sky
colour? I'm currently using the vastly superior version 2.0 for
everything, except this one task where I have to revert to 1.2.
decompose has a new location; and everything else should work the same.
decompose is now located at -->Filters -->Colors -->Decompose
things have moved around some, it took me a while to get used to this.
the changes make some sense, if you think about them. most of the
changes are made between the Image menu and Layers Menu with a few
things that are now located in Filters.
gimp2 also has a new way to locate plug-ins. Xtns -->Plug-in Details.
this should be helpful in finding the location of the old stuff in the
new gimp.
i hope this resolves your problem,
