Clipping path as alpha channel
Clipping path as alpha channel CaptBaldy 05 Feb 23:42
  Clipping path as alpha channel Alexandre Prokoudine 07 Feb 12:56
  Clipping path as alpha channel Alexandre Prokoudine 07 Feb 13:00
2015-02-05 23:42:44 UTC (about 10 years ago)
Hello, complete noob here...
So I have an image that I need to edit/fix before submitting to a online vendor for sale of the product in the picture on their website. I have met all their dimensional requirements and such but I have one that I am completely lost on. Their requirement is directly below:
"Outline Path: Main/Primary images should have an outline/clipping path around the product (where applicable - no need to outline lifestyle images). This outline/clipping path must be saved as a selection (alpha channel). TIFF Transparency is not allowed."
Can anyone help me and explain what they are asking for and possibly how to do this? I have tried to figure it out myself but every time I think I have it I end up with a file with just a white image subject with black background or vice versa.
2015-02-07 12:56:06 UTC (about 10 years ago)
GIMP automatically saves all existing paths as clipping paths when exporting to TIFF. Hence all you need is:
1. Make a selection around the object any way you prefer. 2. Choose 'Select -> To Path' in the menu. 3. Export as TIFF.
Note that the selection should be quite clean. You can test this:
1. Convert the path to selection (from Paths dockable dialog, right-click menu or the bottom toolbar). 2. Press Ctrl+I to invert selection. 3. Press Del or Ctrl+X to remove the area around your original selection.
That will give you an idea how the clipped object will look.
Alternatively you can run a desktop publishing app, create an image frame, load your TIFF file and apply the clipping path.
Alex
2015-02-07 13:00:37 UTC (about 10 years ago)
http://en.wikipedia.org/wiki/Clipping_path
Alex
