Borderless photo not correct
9 of 9 messages available
Borderless photo not correct Tikiman 10 Jan 15:41
  Borderless photo not correct Mark Bourne 10 Jan 20:32
   Borderless photo not correct Gary Aitken 11 Jan 00:05
   Borderless photo not correct Tikiman 11 Jan 11:55
    Borderless photo not correct Mark Bourne 11 Jan 13:27
     Borderless photo not correct Tikiman 11 Jan 14:35
     Borderless photo not correct Tikiman 18 Jan 16:06
      Borderless photo not correct SOLVED Tikiman 18 Jan 16:22
      Borderless photo not correct Mark Bourne 18 Jan 21:42
2015-01-10 15:41:35 UTC (over 10 years ago)
Hello to all I am a very new user of Linux and the supplied Gimp program. I tried out my printer (Canon Pixma MG5550) in gthumb and Gimp by printing a borderless 6 x 4 photo. I changed the settings in the print tab to read Glossy photo paper and size as borderless 6 x 4 and also the orientation to suit my needs. The photo printed okay BUT there is a small border about 8mm at the top and 2mm at the bottom of the photo.in portrait style. This did not happen when I had Win XP and Arcsoft software and after checking as much as I can I am unable to locate a solution. Does anyone know why this happens and can it be resolved?. I would appreciate some help with this please. many thanks
Tikiman
Mark Bourne
2015-01-10 20:32:31 UTC (over 10 years ago)
many thanks
Tikiman
What are the dimensions of the photo? Many digital cameras produce images with a 4:3 ratio, which doesn't exactly fit the 3:2 ratio of 6x4 paper. Either a border has to be left along the shorter edges or part of the image has to be cropped from the longer edges.
I'm not sure if that decision would be down to the software or printer driver, but either way it's possible that GIMP / Linux driver takes the former option so that no part of the image is lost, while Arcsoft / Windows driver may have taken the latter option to produce a truly borderless print at the expense of losing part of the image.
Try cropping the photo in GIMP so that it does have a 3:2 ratio before printing. Also check File > Page Setup in GIMP to ensure it is not adding margins. If that still leaves a border, I suspect it would be more down to the printer or driver rather than GIMP.
Hope that helps. Mark.
Gary Aitken
2015-01-11 00:05:17 UTC (over 10 years ago)
On 01/10/15 13:32, Mark Bourne wrote:
Tikiman wrote:
Hello to all I am a very new user of Linux and the supplied Gimp program. I tried out my printer (Canon Pixma MG5550) in gthumb and Gimp by printing a borderless 6 x 4 photo. I changed the settings in the print tab to read Glossy photo paper and size as borderless 6 x 4 and also the orientation to suit my needs. The photo printed okay BUT there is a small border about 8mm at the top and 2mm at the bottom of the photo.in portrait style. This did not happen when I had Win XP and Arcsoft software and after checking as much as I can I am unable to locate a solution. Does anyone know why this happens and can it be resolved?. I would appreciate some help with this please. many thanks Tikiman
Actually, there is a third option, and I think it is the default for some windows applications: do an asymmetrical resize to fill the paper. You get a distorted image but apparently a lot of people don't notice. (I'm not sure if it's the default or not; I normally don't run win anything.)
I believe it's an option somewhere in the print configuration, something like "resize image to fill paper" (printer driver)
Additional note: If you're printing *with* a border, you want to resize to whatever the final aspect ratio will be, and that will depend on the actual border size. In this case the aspect ratio of the image will not be the same as the aspect ratio of the paper. For example, I print using the smallest border for my epson printer, which is 3mm: 4" = 101.6mm 101.6 - (2*3mm) = 95.6mm 6" = 152.4mm 152.4 - (2*3mm) = 146.4mm 152.4/101.6 = 3/2 = 1.5 146.4/95.6 = 1.53
Gary
2015-01-11 11:55:30 UTC (over 10 years ago)
Hi Mark
I have looked at the properties of the pictures and the only detail given on size is :- Picture width = 5152 Pixels
Picture Height = 3864 Pixels
There are no picture ratios given in properties like 3:2 or 4:3 there are a few other details but none relating to size. I think that I will try to crop or fill the page or even increase the size of the picture to see what happens. Firstly I will create a copy to work on as I don't want to lose the original Many thanks for your input
Tikiman
Mark Bourne
2015-01-11 13:27:10 UTC (over 10 years ago)
Hi Mark
I didn't make explicitly clear that the ratio I was referring to is simply the ratio of width to height. In your case, as I suspected, it's 4:3 (5152/3864 = 4/3).
To crop your image to completely fill a 6x4 (i.e. 3:2 ratio) print, you'll need to make the shorter dimension 3435 pixels (5152 * 2/3 ≈ 3435). So a total of 429 pixels need to be removed; you can control how much of that comes off each side.
Resizing won't help unless, as Gary mentioned, you distort the image by stretching more in one dimension than the other. That may be an acceptable alternative if you don't want to loose anything from the edges by cropping and don't mind the slight distortion. If I was going to do that, I'd keep the shorter dimension as it is and increase the longer dimension to 5796 pixels (3/2 * 3864).
Firstly I
Definitely a good idea! I usually keep the originals even once I've got the final result I want, just in case I want to go back and do something different.
Tikiman
No problem. Hope it works for you.
Mark.
2015-01-11 14:35:45 UTC (over 10 years ago)
different.
Mark.
Thank you for the explicit detail and I will try both suggestions and see what is best. Unfortunately I have visitors from New Zealand arriving today and staying with us for a couple of weeks so if nothing is posted to say what I have done then that is the reason, it is not that I am ignoring anyone. Many thanks again
Tikiman
2015-01-18 16:06:39 UTC (over 10 years ago)
stretching more in one dimension than the other. That may be an acceptable alternative if you don't want to loose anything from the edges by cropping and don't mind the slight distortion. If I was going to do that, I'd keep the shorter dimension as it is and increase the longer dimension to 5796 pixels (3/2 * 3864). Definitely a good idea! I usually keep the originals even once I've got
different.
Mark.
Hi Mark ,many thanks for the data and I have followed your information and have altered the ratio to 3:2 and the paper size remains at 4 x 6 and I am now printing on this size of photo paper corectly as it has achieved the desired result. So now that this has been resolved I will mark the post as solved with thanks to all the input from everybody. Thank you
Tikiman
2015-01-18 16:22:50 UTC (over 10 years ago)
Tikiman
Post is now Solved
Mark Bourne
2015-01-18 21:42:52 UTC (over 10 years ago)
Tikiman
Great. Thanks for posting back to let us know it worked.
Mark.
