GTK3 port status and nightly builds?
GTK3 port status and nightly builds? anatoly techtonik 06 Jan 16:18
  GTK3 port status and nightly builds? Alexandre Prokoudine 07 Jan 00:55
   GTK3 port status and nightly builds? anatoly techtonik 07 Jan 10:05
    GTK3 port status and nightly builds? Alexandre Prokoudine 07 Jan 11:35
  GTK3 port status and nightly builds? Simon Budig 07 Jan 11:49
anatoly techtonik
2015-01-06 16:18:47 UTC (over 10 years ago)
I'd like to use GTK3. Are there any GIMP 3 binaries to test?
Is there a Roadmap of the current problems with GTK3? Will it be possible to use GTK3 without waiting for all stuff to be ported to GECL?
Please CC.
anatoly t.
2015-01-07 00:55:41 UTC (over 10 years ago)
No.
Not in a written way.
Not unless you personally (or somebody else) complete the GTK3 port, sorry.
Alex
anatoly techtonik
2015-01-07 10:05:42 UTC (over 10 years ago)
No.
Is it compiling at least?
Can I compile it myself?
Is it easy?
Are there tests that fail?
2015-01-07 11:35:17 UTC (over 10 years ago)
No.
Yes
I can, and so can you.
Is it easy?
It was easy enough for me.
Not that I know of. AFAIK, bits of UI like custom widgets (e.g. the ruler) haven't been ported yet.
Alex
Simon Budig
2015-01-07 11:49:56 UTC (over 10 years ago)
The main problem is, that Gimp has a library used by 3rd party plugins which provides some GTK+2-Widgets for plugin-ui. Switching to GTK+3 would make these libraries ABI-incompatible with older libgimpwidgets-versions. And since we promise ABI-stability for the Gimp 2.x series this makes it impossible to switch to GTK+3 without switching to a new major (i.e. 3.x) version.
But since we're not ready for a 3.x release (feature-wise) we're between a rock and a hard place here. It is a PITA, but well. Happens.
Bye, Simon
simon@budig.de              http://simon.budig.de/
