Cannot decode a Raw file from Pentax machine
8 of 8 messages available
Cannot decode a Raw file from Pentax machine antonio montagnani 12 Dec 22:23
  Cannot decode a Raw file from Pentax machine Partha Bagchi 12 Dec 22:35
   Cannot decode a Raw file from Pentax machine antonio montagnani 12 Dec 23:19
    Cannot decode a Raw file from Pentax machine Michael Schumacher 12 Dec 23:22
     Cannot decode a Raw file from Pentax machine antonio montagnani 12 Dec 23:29
      Cannot decode a Raw file from Pentax machine Michael Schumacher 12 Dec 23:55
       Cannot decode a Raw file from Pentax machine antonio montagnani 13 Dec 10:45
    Cannot decode a Raw file from Pentax machine Partha Bagchi 12 Dec 23:35
antonio montagnani
2014-12-12 22:23:06 UTC (over 10 years ago)
In the past The Gimp+Ufraw worked fine, I could open a raw file from my Pentax reflex with no issue, suddenly one year ago when I try to open, it doesn't work, I get a window importing from TIFF and another window-TIFF directory is missing required "ImageLength" field. A friend found out this workaround:
whith 0.19.2-6 version installed edit the .gimp-2.8/pluginrc file in user home, search the lines
(load-proc (extension
"3fr,ari,arw,cap,cine,cr2,crw,cs1,dc2,dcr,dng,erf,fff,hdr,ia,iiq,jpeg,jpg,k25,kc2,kdc,mdc,mef,mos,mrw,nef,nrw,orf,pef,pxn,qtk,r3d,raf,raw,rdc,rw2,rwl,sr2,srf,srw,sti,tif,tiff,ufraw,x3f") (magic "0,string,II*\\0,0,string,MM\\0*,0,string,)
Of course any time that a new version of Gimp, I have to edit the pluginrc file.
Any idea?
Please see also:
https://bugzilla.redhat.com/show_bug.cgi?id=1015796
Tnx
Antonio M
Skype: amontag52
Linux Fedora F21 (Twenty one)
on Fujitsu Lifebook A512
http://lugsaronno.altervista.org
http://www.campingmonterosa.com
Partha Bagchi
2014-12-12 22:35:07 UTC (over 10 years ago)
This has been happening for a while.
While opening your RAW images, don't rely on automatic detection, but select the long list of raw formats from the dropdown list and then open your image.
Hope that helps.
Partha
Any idea?
Please see also:
Tnx --
Antonio M
Skype: amontag52
Linux Fedora F21 (Twenty one) on Fujitsu Lifebook A512
http://lugsaronno.altervista.org http://www.campingmonterosa.com
antonio montagnani
2014-12-12 23:19:35 UTC (over 10 years ago)
Partha Bagchi ha scrito il 12/12/2014 alle 23:35:
Hope that helps.
Partha
Any idea?
Please see also:
Tnx --
Antonio M
Skype: amontag52
please read the full report in bugzilla in my previous post.There is only one option in the drop-down list and Gimp doesn't work as expected with the standard pluginrc file.
If I blacklist or delete this line:
it works as expected
Antonio M
Skype: amontag52
2014-12-12 23:22:13 UTC (over 10 years ago)
Please note that UFRaw is a third-party plug-in, and adding the magic is actually done from what the plug-in provides.
Is there a corresponding entry in the bug tracker of the UFRaw maintainers?
antonio montagnani
2014-12-12 23:29:32 UTC (over 10 years ago)
Michael Schumacher ha scrito il 13/12/2014 alle 00:22:
for my information, why does it work when such line is deleted? do you mean that bug is connected to ufraw-plugin (therefore to ufraw)??
tnx
Antonio M
Skype: amontag52
Partha Bagchi
2014-12-12 23:35:27 UTC (over 10 years ago)
It works because, that is the header of a TIFF file as well. Open a tiff file and examine it to verify.
I provided you with a work around. Remember the magic is provided by UFRaw.
Hope that helps.
Partha
file.
Any idea?
Please see also:
Tnx --
Antonio M
Skype: amontag52
-- Antonio M
Skype: amontag52
2014-12-12 23:55:49 UTC (over 10 years ago)
Yes. File plug-ins tell GIMP the magic numbers of the file formats they can handle. And this is when used to select the plug-in to handle a file format.
The magic number is a feature that allows to identify the file format - or at least guess it reasonably well. See https://en.wikipedia.org/wiki/Magic_number_%28programming%29 for more information about this.
antonio montagnani
2014-12-13 10:45:34 UTC (over 10 years ago)
Michael Schumacher ha scrito il 13/12/2014 alle 00:55:
I think that I am hit by this bug:
http://sourceforge.net/p/ufraw/bugs/392/
I suppose that modification has not yet hit the Fedora repos.
Antonio M
Skype: amontag52
