Question about golden-spiral-0.0.py script
7 of 7 messages available
Question about golden-spiral-0.0.py script Dave Thibault 17 Nov 00:54
  Question about golden-spiral-0.0.py script Owen Cook 18 Nov 00:15
   Question about golden-spiral-0.0.py script Dave Thibault 18 Nov 17:00
    Question about golden-spiral-0.0.py script Ofnuts 19 Nov 00:20
     Question about golden-spiral-0.0.py script Dave Thibault 19 Nov 05:31
  Question about golden-spiral-0.0.py script rich2005 18 Nov 09:04
   Question about golden-spiral-0.0.py script Dave Thibault 18 Nov 18:08
Dave Thibault
2014-11-17 00:54:08 UTC (over 10 years ago)
I've got GIMP 2.8 on OSX Mavericks and I'm trying to use this script:
http://sourceforge.net/projects/gimp-path-tools/files/scripts/golden-spiral-0.0.py/download
I've tried putting it in /Users/myusername/Library/Application Support/GIMP/2.8/scripts and in /Users/myusername/Library/Application Support/GIMP/2.8/plugins. I have verified that both of those paths are set in the GIMP Prefeferences/Scripts and /Plug-ins settings. Either way, I get no errors when starting GIMP and I can't find the menu options to use the golden spiral in GIMP. Am I doing something wrong?
Thanks, Dave
Owen Cook
2014-11-18 00:15:49 UTC (over 10 years ago)
I don't know about OSX, but the python script needs python support, you have python installed?
In the unix world, the script needs to be executable, is this the case for you?
Python scripts go in the users plug-ins subdirectory, not in scripts
Owen
Sent: Monday, November 17, 2014 at 11:54 AM From: "Dave Thibault"
To: gimp-user-list@gnome.org
Subject: [Gimp-user] Question about golden-spiral-0.0.py script
Thanks, Dave
2014-11-18 09:04:46 UTC (over 10 years ago)
Thanks, Dave
I am sure ofnuts will be along soon
but on a more general basis, applicable for any plug-in.
Have you made the plug-in executable?
After a Gimp restart, does it show in Help -> Plugin Browser (enter golden in the search box)
If it is not there then it is wrong-place/not-working
Working and that tells me it is in the selection menu.
And indeed it is there and works here PCLinuxOS and Gimp 2.8.14
Dave Thibault
2014-11-18 17:00:16 UTC (over 10 years ago)
Owen,
Thanks for the response. I have python installed:
Python 2.7.5 (default, Mar 9 2014, 22:15:05)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
and I have the script executable:
-rwxr-x--x@ 1 username staff 7980 Nov 14 22:41 golden-spiral-0.0.py
I could just be looking for it in the wrong place. The documentation states that it shows up under "/Select". However, I can't find it under the Image menu or the select menu. Please advise.
Thanks,
Dave
Owen
set
Thanks, Dave
Peace,
Dave
Thibault Fine Art--inspired by light and perspective
http://thibaultfineart.com
Subscribe to my mailing list for free downloads, special offers, and other
great content!
Dave Thibault
2014-11-18 18:08:31 UTC (over 10 years ago)
Rich,
Thanks for the reply.
I have made the plugin executable. After GIMP restart, I can't find it in Plugin Browser. If I search for "golden" all I find is the Golden Rule Guide that I also installed and it is showing up in GIMP and working properly. I don't see the golden spiral at all by searching in the plugin browser.
That does lead to a different question, though. Should this be in the scripts folder or the plugins folder?
Thanks, Dave
Thanks, Dave
the search box)
-- rich2005 (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
Peace,
Dave
great content!
2014-11-19 00:20:00 UTC (over 10 years ago)
On 18/11/14 18:00, Dave Thibault wrote:
Owen,
The plugin should be made executable, in one of the plugins directories (check Edit>Preferences>Folders>Plugins to see where they are).
It should be at the bottom of the Select menu of any image window, and appear in the plugin and procedure browsers (but you have already checked this). You can try to start Gimp from a terminal (if this can be done on OSX). If the plugin doesn't register you will likely see an error message in the terminal window. A frequent cause of problem is editing the plugin, and unknowingly altering the indentation. This causes Python syntax errors that make the registration fail (in case of doubt, download a fresh version).
Dave Thibault
2014-11-19 05:31:42 UTC (over 10 years ago)
OK, it works now. It was a combination of both not being executable AND having it in the scripts folder instead of the plug-ins folder. I had tried both folders but before it was suggested to make them executable.
Thanks, all! Dave
Owen,
Peace,
Dave
great content!
