Help finding the right plugins and filters
7 of 7 messages available
Help finding the right plugins and filters April 04 Nov 16:23
  Help finding the right plugins and filters Pat David 06 Nov 23:08
   Help finding the right plugins and filters April 09 Nov 22:43
    Help finding the right plugins and filters Pat David 10 Nov 16:49
     Help finding the right plugins and filters Pat David 10 Nov 17:16
      Help finding the right plugins and filters April 11 Nov 07:30
       Help finding the right plugins and filters Pat David 11 Nov 16:05
2014-11-04 16:23:30 UTC (over 10 years ago)
Hi everyone. I recently took my daughter's senior pictures and she wants the pictures to look like this photographer's pictures. (http://www.andrew-edwards.com/1gpfy09s1qte4m87lqomiafiq757xt) The all have sort of a dark quality to them. I'm having trouble finding the right filters and settings to achieve this look. Does anyone have any suggestions for me? Thanks so much!
April
Pat David
2014-11-06 23:08:42 UTC (over 10 years ago)
April,
The process to emulate those looks will be dependent on what her images look like to start with. If you can post/send a few sample images I can probably point you in the right direction to get started.
If I had to guess I might lean towards VSCO film presets (you can get similar presets from the G'MIC plugin as well).
Thanks so much!
April
-- April (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
pat david
http://blog.patdavid.net
2014-11-09 22:43:19 UTC (over 10 years ago)
Thanks for offering to help! I have found a couple of tutorials on G'MIC, but it has so many options that I'm just not sure where to start. I have attached a few pictures of different settings. Any help you can give me will be greatly appreciated. Thanks so much!
April
April,
Pat David
2014-11-10 16:49:50 UTC (over 10 years ago)
April,
The particular part of G'MIC I'm referring to is "Film Emulations". There are quite a few different emulations for various film stocks that may get you what you are looking for color-wise.
Bear in mind that the 'darkness' to the images in your first post are due to a combination of processing as well as the exposure conditions at the time. Your sample images have quite a bit of direct sunlight in them, which makes it a bit harder to impart a sense of 'darkness' in them.
April
April,
* http://www.gimpusers.com/system/attachments/167/original/IMG_4641.JPG * http://www.gimpusers.com/system/attachments/168/original/Untitled.jpg *
http://www.gimpusers.com/system/attachments/169/original/IMG_5014_Edited.jpg
pat david
Pat David
2014-11-10 17:16:05 UTC (over 10 years ago)
April,
Because I cannot leave well enough alone, a second example:
https://lh4.googleusercontent.com/-Ca4gKTlu72k/VGDwQNFC2bI/AAAAAAAASOU/_3YxRElY7t8/s0/april-2.jpg
This time it's basically some simple color toning, a vignette, and lifting the blacks again (with some slight split-toning).
On Mon, Nov 10, 2014 at 10:49 AM, Pat David wrote:
April,
April
April,
pat david
pat david
2014-11-11 07:30:12 UTC (over 10 years ago)
Hi again! You said, "a second example" but I don't seem to see the first one. Thanks so much for taking the time to help me with this. I will check out those film filters. Thanks again!
April
April,
Pat David
2014-11-11 16:05:01 UTC (over 10 years ago)
Oh? Let me re-link just in case:
First one: https://lh4.googleusercontent.com/-_BBemcslfSU/VGDsLkisGxI/AAAAAAAASOI/qDOQTfGc6RA/s0/april-1.jpg
Second one: https://lh4.googleusercontent.com/-Ca4gKTlu72k/VGDwQNFC2bI/AAAAAAAASOU/_3YxRElY7t8/s0/april-2.jpg
April
April,
pat david
