Dump question
Dump question Michael Wagner 22 Sep 09:23
  Dump question olivier ripoll 22 Sep 10:13
Michael Wagner
2004-09-22 09:23:12 UTC (almost 21 years ago)
Dump question
I have a dump question: How do I paint a dashed or dash-dotted line in gimp? Thanks
Michael Wagner
www.callacd.com - Ihr persönlicher Downloadservice
olivier ripoll
2004-09-22 10:13:38 UTC (almost 21 years ago)
Dump question
Michael Wagner
Select the path tool (7th tool, between the cissors and the colour picker, or press B) and click or your image at the start point and at the end point. You should see two round dots linked by a thin line.
Then go to the Paths dialog (usually, it is the third tab in the Layers, Channels and Paths window). There is an icon, just before a trashcan which is called "stroke path" (you can also access it via the right click in the Paths stack area above the icons). This should open the "stroke options" window, where you can select the style you want for the dashes.
Best regards,
Olivier.
