Nick Wilson wrote:
Hi all,
I was hoping someone might point me in the direction of a tutorial (or
just tell me what tools to use) for the following:
I need to take a snapshot of someone and then select them out. IE to
ditch the sofa in the background etc and just have a nice shot of the
subject with a transparent bg suitable for use on a webpage.
I know that isnt easily done, hence the email. Anyone know a good
resource? I did search but didnt come up with much....
(sorry, not really an artist, sheesh, even a text logo takes me 2hrs
lol!)
Much thanks...
Although the gimp interface has changed since it was written, have a
look at this section of the excellent "Grokking the gimp":
http://gimp-savvy.com/BOOK/index.html?node47.html
Read the whole chapter about selection and masks if you have time.
You have several alternatives:
1- using the quickmask, you can "detour" the subjects using the paint tools
2- even faster is to add a layer mask to your image (right click in the
layer tab of the layer, channels & paths dock window). Then, you can
select this layer mask and directly paint in it, as seen here:
http://gimp-savvy.com/BOOK/index.html?node44.html
Wherever you paint with black will make the image transparent. If you
are mistaken, just repaint with white and the deleted image reappears :)
As you see on both sections, you can achieve a really good quality. I
would not use the selection tools (wand) for a good result, or only to
start with. Indeed the obtained selection can be used to start the
quickmask (in option 1).
Best regards
Olivier.
PS: I apologise to the mailing-list _if_ the message is sent in HTML. I
have just change my newsreader and although I have set it to send text
only, I may have made a mistake ;)
