How do I insert text?
1 of 2 messages available
mailman.35.1412769608.4211.... 08 Oct 19:34
  How do I insert text? Klaus Gölker 08 Oct 18:50
Klaus Gölker
2014-10-08 18:50:41 UTC (over 10 years ago)
if you are writing text with the Text tool, there may be some other causes, if you cant see the text.
First: check your foreground color. If you are using the same text color as is the background oft he image, you will not see your text. Second: if you are working with layers, make shure the uppermost layer is active before you begin typing. Otherwise the text may be hidden behind an overlaying layer.
Greetings
Klaus Goelker
-----Ursprngliche Nachricht----- Von: gimp-user-list [mailto:gimp-user-list-bounces@gnome.org] Im Auftrag von gimp-user-list-request@gnome.org
Gesendet: Mittwoch, 8. Oktober 2014 14:00 An: gimp-user-list@gnome.org
Betreff: gimp-user-list Digest, Vol 37, Issue 5
Send gimp-user-list mailing list submissions to gimp-user-list@gnome.org
To subscribe or unsubscribe via the World Wide Web, visit https://mail.gnome.org/mailman/listinfo/gimp-user-list or, via email, send a message with subject or body 'help' to gimp-user-list-request@gnome.org
You can reach the person managing the list at gimp-user-list-owner@gnome.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of gimp-user-list digest..."
Today's Topics:
1. Re: Game of GIMP (Gunold Brunbauer) 2. Re: How do I insert text? (Steve Kinney)
Message: 1 Date: Tue, 07 Oct 2014 19:35:05 +0200 From: Gunold Brunbauer
To: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] Game of GIMP Message-ID:
Content-Type: text/plain; charset=utf-8; format=flowed
I think GIMP deserves some promotion. Thats why I implemented a "Game of GIMP". You can find it here: http://www.bilderstroeme.de/gameOfGimp. I hope you have fun and use it to promote gimp. I would like to make a version for android and iphones, too, but I don't have a developer-account. So I'm looking for someone who could be able to put such a version into the aplle store or into th google play store. Thanks,
Gunold
First: check your foreground color. If you are using the same text color as is the background of the image, you will not see your text. Second: if you are working with layers, make shure the uppermost layer is active before you begin typing. Otherwise the text may be hidden behind an overlaying layer.
Greetings
Klaus Goelker klaus@goelker.com
Message: 2 Date: Tue, 07 Oct 2014 19:36:43 -0400 From: Steve Kinney
Subject: Re: [Gimp-user] How do I insert text? Message-ID:
Content-Type: text/plain; charset=UTF-8
On 10/07/2014 12:05 AM, Paul_Mccarthy wrote:
Hi everyone,
As hard as I try to follow tutorials etc, I can't see text when I try to add it to a photo.
The Help file within Gimp suggests that if I select the Text tool and click on an area of the canvas, I should see text as soon as I start typing.
The text comes up in the "Layers - Brushes" sidebar and I can see a cursor moving in the text box on the canvas, but I see no text on the canvas at all.
That's quite bizarre - there is no connection between the Brushes dialog
and the text tool - if you see a moving cursor on the image canvas,
nothing should happen anywhere else while you type. My first impulse
would be to check whether I had the current stable version of the GIMP from
an "official" source - and even if so, I would reinstall it anyway just to
make certain.
If you don't see the text appearing in in the image as you type, that
might be because it's too small to see: The larger the image you are adding
text to, the harder the letters will be to see, unless you have selected a
font & size that are large enough to show up. Next time around try
typing something, do Control+a to select what you typed, and increase the
size via the on-canvas control box to see what happens. Worth a try
anyway.
:o)
Steve
-----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.14 (GNU/Linux)
iQIcBAEBAgAGBQJUNHkLAAoJEDZ0Gg87KR0LAiIP/01EuB/7o5Qe2GpVf9zHWDLL kCv+EowFMtU5bHEaqUm96ODz3bazozP3BD2Wkgvtc1BhZpkmcT4Mg9auQGv/sALv LDsBQMPAxFKaaEq5WkMQYn4y96g0xj+Zu1DljYIS1PefsJ9WT4D9Ms/RbuBoN3qp u53Wt4uOMZFoMIUFlJpgqPAljnyyFG8y+V0XBSvDbRw8lFJ5ZoGS24uS9zHgYTVu 6KqaFHC2uLTlAGzpIr8VuSxLbGiZFiO3SYbKXxparGUopd1NVKN58ePNAQY0/Bs/ F5qI2VYiDW/nV3/0icZXOxnvnggXbfIxPyHXHL44x2v7RqprojZiDvCCiJbae+gM u8df2v9d/Vimr3poSB5z3VnoLXS5yRhwn8qRn9ukauK5es52gLUFQRbk9Aw9G8wt vyN8dljN9GrAbUcsIDsNdyGa0/BQ8cT16nloSON9Q7Ew6o3FEM1eZYulqL0V4Q6y vS1d/MvJOExnMaojL+hovPQOWJbacJX0Sa6cRIZxPmKXR9lXGj6kgMuXd3QZLeEU 2OMatLX/tvZOuVNzNGaLTkeQav71r9uRIxbLQqNNvgljEz+t97o4kQESYgMhgj34 b/Fq1J/kOMjMV4ITyt+JOPx7RuQnzDmgsSRFTVBEsr2JSOBZ8sXuitxb/yfefZQB zF6Jyxw9bLyaL9tX95k9
=fByi
-----END PGP SIGNATURE-----
Subject: Digest Footer
