JPEG Help
JPEG Help Tibbins, Aimee 21 Aug 13:02
  JPEG Help Alexandre Prokoudine 22 Aug 09:28
  JPEG Help Ofnuts 22 Aug 10:18
  JPEG Help Greg Chapman 22 Aug 13:25
Tibbins, Aimee
2014-08-21 13:02:17 UTC (over 10 years ago)
JPEG Help
I am currently using GIMP 2.0 for some work related graphics. When I go to save the image they only save as a xcf. File instead of JPEG. Wondered if anyone was able to help with how I get them to save as a JPEG?
Thanks, Aimee
Please consider the environment before printing this email.
E-mail messages may contain viruses, worms, or other malicious code. By reading the message and opening any attachments, the recipient accepts full responsibility for taking protective action against such code. Henry Schein is not liable for any loss or damage arising from this message.
The information in this email is confidential and may be legally privileged. It is intended solely for the addressee(s). Access to this e-mail by anyone else is unauthorized.
2014-08-22 09:28:14 UTC (over 10 years ago)
JPEG Help
Hi Aimee,
Please use 'File -> Export...' menu item instead.
Alex
2014-08-22 10:18:36 UTC (over 10 years ago)
JPEG Help
File>Save only saves to XCF. For other filetypes, use File>Export (and consider keeping the XCF file around in case you find you need to do further changes).
Greg Chapman
2014-08-22 13:25:53 UTC (over 10 years ago)
JPEG Help
Hi Aimee,
Export the file to the desired format.
As you say saving saves to GIMP's native format.
Simple really> :-)
Greg Chapman http://www.gregtutor.co.uk
