Enlarging images for print
Enlarging images for print Kevin Waterson 15 Sep 23:38
  Enlarging images for print Steve Stavropoulos 19 Sep 02:45
Kevin Waterson
2004-09-15 23:38:37 UTC (over 20 years ago)
In photoshop, a process of enlarging images is done little by little using bi-cubic. This is done in small steps to assure a closer fill in with pixels. What method does the GIMP use?
My goal here is to enlarge a 6MegaPixel (2000x3000) image from a digital camera to about 40" x 60".
Kind regards Kevin
______ (_____ \ _____) ) ____ ____ ____ ____ | ____/ / _ ) / _ | / ___) / _ ) | | ( (/ / ( ( | |( (___ ( (/ / |_| \____) \_||_| \____) \____) Kevin Waterson
Port Macquarie, Australia
Steve Stavropoulos
2004-09-19 02:45:14 UTC (over 20 years ago)
GIMP uses whatever you tell it to use. Look for interpolation in the Image -> Scale Image options. You can change the default from File -> Preferences -> Tool Options -> Default interpolation.
