Spacing of text in myriad pro bold suddenly changed
Spacing of text in myriad pro bold suddenly changed brc131 07 Jul 21:00
  Spacing of text in myriad pro bold suddenly changed Steve Kinney 08 Jul 03:15
  Spacing of text in myriad pro bold suddenly changed judah 21 Jul 16:48
2014-07-07 21:00:20 UTC (over 11 years ago)
I'm having an issue with the myriad pro bold font. The spacing of the letters changed all of a sudden. I've closed, restarted, uninstalled, reinstalled a few different versions and nothing seems to work. I've played around with font size, hinting without luck as well.
Attached is an example of the spacing being off. It can be seen best in the word 'calcaneous' in the attached image. On the left, the text is normal looking. On the right, the spacing of the letters is off. I hadn't made any changes when this distortion started occurring.
The text in this image is myriad pro bold, 14 px. I'm using version 2.6.12 here (because I find it's easiest for me to use for what I need to do) but I've also updated gimp and tested the font in the latest version with the same result.
Thank you for any help you have to offer!!
2014-07-08 03:15:26 UTC (over 11 years ago)
In GIMP 2.8, the on-canvas text tool can adjust the kerning (horizontal spacing) of text. Put the cursor between the letters you want moved together or apart and use the lower right box in the floating text dialog box. Picture worth thousand words:
http://pilobilus.net/xfer/kerning.png
This should work. As for the underlying problem, that's a mystery so far. I never saw anything like it, in a "familiar and well tested" font.
:o)
Steve
-----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQIcBAEBAgAGBQJTu2JLAAoJEDZ0Gg87KR0LDT8P/j4LTBy2KPLv3sv9OX6UFDz0 aZLQXQ8coW9P5l/syk6ATYDq1WKUsEqqlnmzVAXpvAxtPxbsZbAwwqze/66l1Q1+ PjLwOdUWkHJdvFOuJBLpdJ7v0YvP90or/QIDB3OlnYGcQgmbThCIh5OsS3LEMiA5 c6ivloJPb26tOGX7aKORmV7iVROlsMELCdxH0acSAYcp8O+uCPhLJ75Tnives+r1 auDA8PJ1gV3Qi9B1UW3CmFqHcrZcJdMvwRTCsvDn8JIhDSSK6jPonGDIvzpzL4Ds sLQW2gM+BwWmSTxD+s8tyBl/9RyGHRJtrjXzxm55NRggSIGc11kL5G8aKC+lp0nS d8HGur0Tljc1z1m9O0JndjpFa30bT5JVwzsqa+yVXFm2Jqmxl46lvzQ20PhfRA2B 8edV82JxKgoyxDe84uBbcHEpyAQPM6Klt1jUc8D6+ueiCAZCFiX5CCBA+g700ooh iixdLRc/cGIV8GWekTKAnLe6jBI0MYCaoKxhscfOf/bjti+eGj0QOvVEahAq0iSB XrzPAeJHz3oRg6eza3Gd3QB5WhWdfkAOCvsl+qVCJWUNkeJAMUGwyyMxFQtSmwMW 6zwT9ugI5ybgrxKC0Ch+517DFRUivXpHlntp4yklEdkgkK8A582im4grh9njiZ4z jaiTNZz08+VGQDEhGXha
=8XUE
-----END PGP SIGNATURE-----
judah
2014-07-21 16:48:33 UTC (about 11 years ago)
brc131 gimpusers.com> writes:
letters
few
size,
word
On
Looking at the two options you provided, the text in the problematic text box seems distorted, it looks like you may have somehow stretched the original dimensions of thectext box. If you have the file copy the text from the text box, paste it into a new txt file, delete the problematic layer and paste the text in a new text layer.
here
also
Granted you posted this a month ago, I hope it helps in future.
