Move Tool glitch
Move Tool glitch PantsParty 27 Jun 00:28
  Move Tool glitch scl 27 Jun 03:07
   Move Tool glitch PantsParty 28 Jun 00:15
2014-06-27 00:28:02 UTC (almost 11 years ago)
Move Tool glitch
hey team
been running GIMP for years, now running version 2.8.10 on OS X 10.8.5
Now a very annoying glitch that was not present on 2.6 (the last version I ran). I use the scale tool to resize an item. Then I press 'M' to move the item. My cursor turns into some kind of bezier tool with a no-go symbol -- I'll attach a screenshot below -- and then I am unable to move anything. The only way to make that go away and get back my Move Tool is to quit and restart.
This is very aggravating! As I said before, I never had this problem until I got the latest build. This happens when I copy an image, paste it into another window and anchor the layer. It also happens when using the scale tool.
many thanks for any help! Paul
scl
2014-06-27 03:07:13 UTC (almost 11 years ago)
Move Tool glitch
Hey user,
I can reproduce this exactly. The cause is that the Move tool is set to move paths but after scaling an item you are working on a floating selection. Therefore you see this cursor symbol and moving doesn't work. To solve this, go to the Move tool and in the first line of the tool properties dialog ('Move') click the first toggle button ('Layer'). Then try to move again.
I hope this helps.
Kind regards,
2014-06-28 00:15:31 UTC (almost 11 years ago)
Move Tool glitch
Ah fantastic thanks Sven that solved it!
Hey user,
I hope this helps.
Kind regards,
