Accented Character Problem
Accented Character Problem leo@secline.com.br 10 Sep 13:45
  Accented Character Problem Sven Neumann 10 Sep 17:16
leo@secline.com.br
2004-09-10 13:45:18 UTC (over 20 years ago)
Hello all:
I've just upgraded to gimp 2.0.4 from 1.2
It's quite an improvement. Thanks to you developers, for such a good job.
However...
I need to create text with accents from the latin1 charset. They all work except for one. ccedilia `ç' It appears with the mark above the `c' as though it where an actute accent.
It's a gimp specific issue as this rxvt term has displayed it correctly above.
Any comments?
Leo
2004-09-10 17:16:54 UTC (over 20 years ago)
leo@secline.com.br writes:
However...
It appears as such in both the GIMP text editor and on the text layer? If that is the case then you are simply not inputting the right character. You might want to use the 'Cedilla' GTK+ input module. Try if selecting that module from the right-click menu in the text editor solves your problem. If it does, you can make this the default input module for GTK2 applications.
That doesn't really make it a GIMP specific issue.
